Home > Puma (Tdci) > Leak
mse
Leak
I know an common question...In heavy rain, when i park in a certain place on the drive and only occasionally there is a very small amount of water on the matt - passenger side.
Now before i and the dealer have looked and couldnt find anything
Today i noticed a dop of water on the grille of the air box at the top of the passenger footwell
Is this a known location, is it a problem or is it water just getting through the system? Mike
Post #5470 13th Dec 2008 10:05pm
Grockle
I think first the windscreen seal or the one baulkhead to windsceen frame,and I thought yours was a water tight one. 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #5475 14th Dec 2008 10:37am
mse
it is.
is not the windscreen or the bulkhead to windscreen frame im 99.9% sure of that Mike
Post #5486 14th Dec 2008 6:15pm
Edd80Inch
United Kingdom 1999 Defender 90 Td5 HT Rioja Red
My 90 leaks in the same place as yours by the sound of it, I always thought it was through the heater recirculation vent, only now and again and enough to make a small puddle on the mat.
My dealer says he cant find a leak as the water out of a hose is a different viscosity to rain water,,,, Must be a relation of Stevie Wonder................
Edd 1999 90 TD5 County
1943 Ford GPW Jeep
Post #5492 14th Dec 2008 8:48pm
mse
Edd
Thats the one - its not leaking as a leak i think the water is getting in the wing vent and down into the box through to the mat on heavy rain.
Ive tried the hose, power wash and dealer - we all cant get it to leak on the window/door/seals/joints and having seen this straight out the middle of this vent - its not the standard leak, no damp on the bulkhead or dash - so...why; ill see when i change the vents. Mike
Post #5493 14th Dec 2008 8:54pm
Caterham
similar problem different side though?
noticed nothing for a couple of months (although perhaps we didn't have much rain -cant remember) and now a wet mat, dripping from what appears to be the bottom bracket for the dash board next to the retaining arm / strap for the door.
Post #5494 14th Dec 2008 9:24pm
mse
Totally different sorry Mike
Post #5495 14th Dec 2008 9:43pm
Grockle
Caterham, I would check windscreen and baulkhead seals as I thoght that might have been Mikes problem areas 2.4 90 XS
Post #5501 15th Dec 2008 8:27am
Paul55
England 2008 Defender 90 Puma 2.4 XS CSW Santorini Black
Has anyone had the problem of the leak resolved, just booked mine into the dealers this morning as I had a small swimming pool on the passengers footwell side this morning, after huge downpour in sunny Derby last night Very Happy . It would be nice to take her in and have some info for them. Cogito ergo sum
Post #9716 15th Apr 2009 10:43am
Grockle
Windscreen seal,windscreen hinge bolts,door hinge bolts. 2.4 90 XS
Post #9718 15th Apr 2009 11:30am
Eduardo
Thanks grockle
Mine have the same problem from new Sad
Has been checked several times by the dealers but nothing has been solved
Is now with the dealers for paintwork, so I will pass your info to them to be checked.
Cheers! Eduardo
Post #9720 15th Apr 2009 2:08pm
110SEB
Ours has finally been resolved after 5 or so visits to the dealers. It was taken to a 3rd party LR body shop three times and stripped and water tested. It seems to have done the trick although i won't be surprised to see a few drops on the mat in the winter. Bulkhead was the culprit apparently.
As the main dealer told me when we were in full flow (excuse the pun) of arguments, "9/10 Defenders leak - farmers expect it"
We were told that it was hard for them to test for leaks as rain water "is finer than tap water" and therefore might not penetrate the gaps in the overnight water test.
I must get that tattoo saying 'gullible' removed from my forehead.
Post #9722 15th Apr 2009 2:26pm
