Home > Maintenance & Modifications > Brake kits, what are the options |
Pickles Member Since: 26 May 2013 Location: Melbourne Posts: 3781 |
Depends on a few things.
Your Budget,...You can spend PLENTY. Are you keeping the standard 16" wheels, or going to 18" which will enable you to fit some very nice brakes. Are you doing front & rear?....I would suggest that you do, and that you buy this upgrade as a "kit", so that all testing has been done, & your brakes will be improved as you would expect. If you go to 18" wheels, then I'd suggest AP 6 spot fronts & 4 spot rears, ... you could then fit an LS3 with no further worry about brakes! Lots to choose from! Pickles. |
2nd Jul 2016 12:41am |
Spectre Member Since: 26 Jan 2016 Location: South East Posts: 228 |
To fit 16" wheels.
Would look at front and rear. |
2nd Jul 2016 5:45am |
Any further input on this?
10th Jul 2016 5:56pm |
Likeomg Member Since: 29 Jun 2012 Location: Lake District / Newcastle Posts: 2637 |
Contact bowler, they have a kit to fit 16" i believe.. all others are 18" plenty pics in my, "my defender' of uprated brakes...
10th Jul 2016 8:00pm |
Disco_Mikey Member Since: 16 Nov 2014 Location: Dundee Posts: 531 |
Standard size discs, with uprated pads give a decent upgrade without breaking the bank
Or, you can opt for drilled/grooved discs |
10th Jul 2016 8:01pm |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10731 |
As Micky has said, ive upgraded my brakes, ive got drilled/grooved discs all round and ebc pads as well, i did this as i do alot of towing and the landy being loaded up as well, i have found it much better and the brakes dont fade at all 1996 Golf Blue 300Tdi 110 Pick up.
Keeper. Clayton. |
10th Jul 2016 9:26pm |
