Home > Maintenance & Modifications > Brake kits, what are the options
Spectre
Hi guys,
Looking at upgrading the front brakes on the Defender.
What are the options, 4 pot, 6 pot? what should I budget?
Looking forward to some input.
Post #545221 1st Jul 2016 11:44pm
Pickles
Depends on a few things.
Your Budget,...You can spend PLENTY.
Are you keeping the standard 16" wheels, or going to 18" which will enable you to fit some very nice brakes.
Are you doing front & rear?....I would suggest that you do, and that you buy this upgrade as a "kit", so that all testing has been done, & your brakes will be improved as you would expect.
If you go to 18" wheels, then I'd suggest AP 6 spot fronts & 4 spot rears, ... you could then fit an LS3 with no further worry about brakes!
Lots to choose from!
Pickles.
Post #545231 2nd Jul 2016 12:41am
Spectre
To fit 16" wheels.
Would look at front and rear.
Post #545240 2nd Jul 2016 5:45am
Spectre
Any further input on this? Thumbs Up
Post #547589 10th Jul 2016 5:56pm
Likeomg
Contact bowler, they have a kit to fit 16" i believe.. all others are 18" plenty pics in my, "my defender' of uprated brakes...
Post #547636 10th Jul 2016 8:00pm
Disco_Mikey
Scotland 2009 Defender 110 Puma 2.4 DCPU Keswick Green
Standard size discs, with uprated pads give a decent upgrade without breaking the bank Thumbs Up
Or, you can opt for drilled/grooved discs
Post #547637 10th Jul 2016 8:01pm
L110CDL
As Micky has said, ive upgraded my brakes, ive got drilled/grooved discs all round and ebc pads as well, i did this as i do alot of towing and the landy being loaded up as well, i have found it much better and the brakes dont fade at all Thumbs Up 1996 Golf Blue 300Tdi 110 Pick up.
Keeper.
Clayton.
Post #547673 10th Jul 2016 9:26pm
