![]() | Home > My Defender > Corris 90 |
Top work
![]() ![]() My build thread http://www.defender2.net/forum/topic17615.html |
ginjez Member Since: 18 Sep 2011 Location: huddersfield Posts: 1767 ![]() ![]() |
She had a visitor today who just popped by for a spruce up
I hope you gave that zip tie a 'trim' !!!
Trust you to spot that
Cake Member Since: 10 Jun 2015 Location: Essex Posts: 277 ![]() ![]() |
Great looking truck!
Best of luck with your undersealing - just undertook my own last weekend completing most of it and found it very rewarding and like everyone said you get very dirty! Just cover yourself in fairy liquid after and it comes off - also make sure you cover the ground around the car too quite a bit out or you get plenty of overspray from the cavity wax as I learnt the hard way |
Thankfully I'll be in a pit for the task that lies ahead. I've tackled it before on previous Defenders so overalls, filtered mask and spec's at the ready
I'll bring the 90 up, it needs some anti corrosion treatment
The underside has now been treated and the corrosion prevention continued tonight.
Any body looking on would think I must be mad - window blocks removed, masking tape to underside of screen gutter and sealant in hand. Windscreen rubber sealed to surround and sealant applied to foam strip under gutter. Thinking about it - I am mad; I shouldn't be having to do this to a nearly new Defender ![]() |
Pickles Member Since: 26 May 2013 Location: Melbourne Posts: 3789 ![]() ![]() ![]() |
G'Day from Aussie.
What sort of sealant did you apply to the foam strip? Pickles. |
I use an MS polymer pu sealant which is a lot thicker than silicone. You will need to mask up the area as it is very sticky. Use a strong mixture of washing up liquid to smooth off.
chrisbridgeave Member Since: 22 Feb 2016 Location: Lancashire Posts: 66 ![]() ![]() ![]() |
Very shiny Corris grey 90 you have there -and much nicer than mine - how do you do it?
OK thanks, so it just sits on top of the foam & doesn't sink in like Mr Tolleys Sealer? Pickles. |
That's correct, it doesn't sink.
@ Chris, I use various products in the cleaning process. When I first got this I washed using steam cleaner with a wash/wax through the snow foam gun, clayed using a Farecla mit followed by Farecla super resin wax and Farecla black top. I top up the shine with Greased Lightning showroom shine ![]() |
