![]() | Home > My Defender > Corris 90 |
ginjez Member Since: 18 Sep 2011 Location: huddersfield Posts: 1766 ![]() ![]() |
![]() Click image to enlarge ![]() Click image to enlarge All external mods are finished. |
Looking great
![]() ![]() My build thread http://www.defender2.net/forum/topic17615.html |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10859 ![]() ![]() |
Thats what the roof rack is for
![]() 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
Your landy is looking really good ginjez, loving it
Totally agree with you there ginjez
Hairy Dan Member Since: 25 Apr 2013 Location: NW Durham Posts: 1426 ![]() ![]() ![]() |
It looks fantastic
![]() ![]() -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
After living with an annoying rattle from day one and much investigation I have today found the culprit. I've removed trim, checked the towing equipment and all with no answer.
![]() Click image to enlarge It's the galvanised bracket that sits above the seat belt spool. If you've got the same then look here first. I removed it and applied pu adhesive to both flanges to bond it in place and then refixed it - hopefully problem solved. |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10383 ![]() ![]() |
The quest for a quiet Defender...
jk84 Member Since: 17 Feb 2015 Location: Wherever my Defender takes me... Posts: 720 ![]() ![]() ![]() |
...is a never ending story
![]() Mr JK's 90 has a rattle coming from that area. I normally identify them by letting her drive and I crawl around the truck ![]() ![]() MY16 Santorini 90 HT - sold |
Been out tonight and the rattle is cured
This is the stereo system I've fitted. Having the Transit custom with dab, text to talk and voice commands as standard I felt I needed it in the Defender too. The dab aerial is the screen type which is stuck to one of the alpine windows. I think this stereo looks more oem than the Alpine unit - it even has auto dimming when lights on. Finding the loom adapter was a bit of a pain ( no iso plugs in the 2.2)
Fitted the mud under cubby sliding drawer unit together with mud cubby tray.
Drawer unit works well even though I have the cargo barrier behind the bulk head removal bar. ![]() Click image to enlarge |
Cool bit of kit.
![]() Click image to enlarge A member on disco4 has advised someone never to buy a used vehicle from a builder type. I could almost be offended ![]() |
