Home > Maintenance & Modifications > fitting stainless sills, removing old bolts...
Stacey007
Hello
Since doing my sound proofing and mats etc all out I though to fit stainless sills....aarrgghh cannot remove the two allen key? bolts towards the front of the drivers footwell. Soaked in WD40
Do I try and saw them off?
Phaffing around last night aarrgghh these are the ones I cannot move, well they are under this mat in this location (not my car) just picture to show.
The others look ok as they are bolts
Post #546810 7th Jul 2016 11:05am
Happyoldgit
If they just run into nuts on the underside then just grind the heads off [with an angle grinder]. Steve.
http://forums.lr4x4.com
Post #546818 7th Jul 2016 11:50am
mikeh501
those are M10 i believe and go into nuts on the under side. I actually think the nuts might be in the channel of the sill too. They will definately be caked in mud and crap underneath.
Even given all that I would try and get a socket on the nut underneath and then try it from there. I did mine with a 18v rattle gun which got them out ok after some swearing. If that doesnt work id drill them out from above, or possibly grind the head off, again from above.
some advice when you replace, would be to ensure you buy a bolt with no more length than is necessary as this will make it easier to remove the next time.
Post #546820 7th Jul 2016 11:55am
Green Machine
I recognise that photo! Shame the rocksliders don't look like that anymore - about to be replaced. 2005 Td5 | 90 Station Wagon | Tonga Green
Post #546823 7th Jul 2016 12:01pm
Stacey007
^ Sorry I took it from google images
Good to hear not just me that had problems with these heads...I will get them off somehow!!
The new bolts that came with the kit are much shorter and generally look much better quality so hopefully re fitting will be easier...
Post #546934 7th Jul 2016 7:36pm
Stacey007
Well what a pain in the flipping neck...
Getting the old bolts off.... I did it but it involved a drill !! I was even thinking should I re-drill the sills but didn't fancy that either.
So they are off ready for me to clean everything, rust proof and then fit the silent coat up to them and carpet
I've 3 others left to do aarrrgghhh Big Cry
Post #547183 8th Jul 2016 7:40pm
Chris86
United Kingdom 2005 Defender 110 Td5 USW Chawton White
Small set of mole grips was the weapon of choice when I removed my floors last....
You'll need to replace the bolts with new though afterwards- they make a right mess of the heads!
Chris
Post #547198 8th Jul 2016 8:08pm
miker
Easy outs,
Impact driver,
Grinding a slot in the head.
Some combination of the above usually works!!
Post #547242 8th Jul 2016 10:56pm
Stacey007
OK so 3 hours later one side of the car is done with new bolts, washers, rust prevention and silent coat noise deadening fitted,
Rear bolts un done and cleaned ready to rust proof and refit
Rear fitted, doubt the kids will even spot them Very Happy
Front ones... with original carpet back in (over silent coat)
Then with rubber mat and over mat...
Looks pretty smart so I'm happy although I thought would be a quick job..... Laughing Might treat it to some new over mats next.
Just need to do the passenger side now !!! aarrgghh Very Happy
Post #547349 9th Jul 2016 2:17pm
defender9
United Kingdom 2015 Defender 90 Puma 2.2 SW Keswick Green
After all that work is it any quieter?
Post #547355 9th Jul 2016 3:20pm
Stacey007
^ Hello
I've not done all the truck yet.
Rear load area and over rear arches
Rear second row foot well
Front Drivers side under mat
both front doors.
I would say up to around 40 mph so far yes, a little better. Over that harder to tell as other noises such as the wind take over Smile The doors shut with a thud though and adding more will help with the noise I'm sure. Its Never going to be quite.
I do wonder if more under the bonnet would help also
It's on my list
Post #547381 9th Jul 2016 6:38pm
I've got to do my doors with Dynamat too. Thumbs Up
The good thing with soundproofing within SS sills also is the soundproofing is a good isolator too.
That helps dissimilar metal corrosion prevention.
Post #547385 9th Jul 2016 6:46pm
