Home > Maintenance & Modifications > 90 dynamat soundproofing kit? - dynamat |
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3760 |
Hello
I'm unsure how much you need to cover the areas you say. I'm using Silent coat and a 6mm soft cell padding and doing it myself. For a 110 XS I had some quotes and most £1200 upwards... its mainly labour as not a hard job. So far I've spend around £200 on 2 bulk packs of Silent coat, and a 5M roll of soft sell foam, roller, tape etc One box of the bulk pack covered the rear load area including up the sides to the start of the windows and the rear arches. Also the two front door inners, under the drivers footwell and 3/4 of the rear passenger footwell at which point I've opened a new box. I'm surprised at how far a pack has gone. I'm also covering more of the car than the OE carpet covers so will add some extra carpet to cover the it. It depends on your time I guess? I don't like paying for stuff I can at least have a go at. its really easy to work with, and use a roller to squash it down. My biggest difference so far it the front doors, they shut more like a normal car and not a tin can For your £330 I would probably have covered the whole inside, bonnet and roof but my labour is free and I'm enjoying doing it. I'm also lucky and can work under a carport with the doors open in the bad weather It does not sound too bad (joke there somewhere), dynamat it more expensive to start with. Thing is doing it yourself you know what you have done and can check the condition of the bolts etc after you remove the carpets. I cleaned all the areas I'm about to fit the stuff and even rust proofed the bolts etc before apply the matting on top... Tools etc Click image to enlarge dorr done Click image to enlarge Boot in progress Click image to enlarge 6mm Soft cell on top Click image to enlarge |
5th Jul 2016 1:18pm |
Likeomg Member Since: 29 Jun 2012 Location: Lake District / Newcastle Posts: 2642 |
i used 5 boxes to completely cover a def 90...
5th Jul 2016 3:01pm |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1764 |
deadening.co.uk were offering a 10% discount to forum members on silent coat, can't find the post though!
5th Jul 2016 4:01pm |
Grenadier Member Since: 23 Jul 2014 Location: The foot of Mont Blanc... Posts: 5841 |
Double-0, likely to follow your choice of materials. Out of interest, where are you putting the 6mm soft cell? Everywhere or have you been recommended key areas? Also, what have you done with the roof? Silent coat or something else? Monsieur Le Grenadier I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
5th Jul 2016 4:52pm |
Hello
I've not put 6mm foam in on the doors but I have all over the back so far including arches, Roof I will use silent coat I'm more than happy using it and very easy to use. If I take the door panels off again I may add foam, no harm? The only trouble making everywhere so thick is it becomes hard putting stiff back together as its about 8mm thicker. Fitted a new Stainless boot sill with longer screw this evening. Likeomg dd you use 5 x bulk packs? that seems a lot have you side windows? http://www.deadening.co.uk/products/silent-coat-2mm-deadening-mat Grenadier are you anywhere near Annecy Cheers]] |
5th Jul 2016 8:20pm |
domm786 Member Since: 14 May 2016 Location: Scotland Posts: 56 |
Thanks for that info Double-0 ! I did look into soft cell etc. however i have heard this can hold moisture very easily! and the carpets that im waiting on (exmoor) can hold a maximum of 4mm thickness underneath them. Hopefully i can still get a door sill on the rear! I've managed to haggle the price down a little on the dynamat so looks like that will be the best option! I will update when i have completed the job Cheers, Dom |
5th Jul 2016 8:40pm |
Thanks Double-O. Will speak to Sound Deadening and see what they say as a DC offers up unique challenges vis a vis the rear bulk head etc. Ta
And yes, I'm about 45 mins from Annecy and indeed will be there on Friday with Mrs Grenadier blowing exorbitant amounts on sofas, money which could have been well spent on the Defender or even mapping her TT... Monsieur Le Grenadier I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
5th Jul 2016 8:41pm |
Stiff1 Member Since: 09 Dec 2014 Location: Cornwall Posts: 597 |
Stacey007 - Out of interest, when you did the doors, did you remove the frame work or can you get the Silent Coat all the way to the top with just the door card removed? Hope that makes sense.
6th Jul 2016 7:53am |
