Home > Maintenance & Modifications > Exhaust fabricator |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6298 |
Click image to enlarge Something like that? |
4th Jul 2016 8:28am |
Cake Member Since: 10 Jun 2015 Location: Essex Posts: 277 |
Just like that - just for a 90, so exiting within the arch over the mudflap..
I believe the rear silencer doesn't make much difference so without preferably so its tidier in the arch. Something like below for what you would see - |
4th Jul 2016 8:35am |
Click image to enlarge Cake, this is the original exhaust....just with a bit of tlc and autosol might have saved you a few quid? |
4th Jul 2016 8:43am |
My god I never expected it was possible with standard steel!
I think its going to be worth giving that go - thanks so much! |
4th Jul 2016 9:02am |
hi Cake,
very possible - I pinched the idea off someone else. I think you'll find the original is s/s but a low grade hence it doesn't rot but also doesn't polish as well as some s/s but is ok for me and to be honest in my opinion polishes sufficiently well to suit the defender. |
4th Jul 2016 9:05am |
Well I think you have saved me a few ££'s and given yet another job for this weekend
Thank you so much - I will document the before and after |
4th Jul 2016 11:00am |
I took your advice and after a little wire wool and remove grit and some Autosol for only 20 minutes worth of effort i got a very surprising result!
Thanks so much for letting me know and saving more ££s, i will put more effort soon enough but amazed already with the outcome. Before: Click image to enlarge After: Click image to enlarge Click image to enlarge |
11th Jul 2016 12:47pm |
Brill.
Good effort. |
11th Jul 2016 12:51pm |
Wow. Mine's just black and grimy.
11th Jul 2016 2:19pm |
Tommo Member Since: 19 Dec 2013 Location: Leicestershire Posts: 830 |
Yip, mines got waxoil overspray on it
11th Jul 2016 4:34pm |
DonH2000 Member Since: 12 Jan 2015 Location: North Kent Posts: 551 |
Glad you are sorted however if you want a custom built exhaust in the future try Pipecraft in Basildon, excellent fabricators and I bet they are just up the road from you!!! Cheers Don.
12th Jul 2016 9:25am |
