Home > Technical > Defender Front Heated Screen wiring query
Bruce S
Howdy,
I have fitted a new front heated screen to my defender 90. It is a non genuine screen that has three wiring connections on its bottom edge. (one at either end and one in the middle).
I do not know what the three connectors need to be connected to?
My bulkhead loom has a connection on either side that I assume is the power, and I am wondering if the central connection on the screen is the earth?
Can anyone advise me on how the new screen needs to be connected please.
Appreciated!
Very Happy
Bruce S
Post #54541 22nd Jan 2011 5:38pm
Grockle
only seen them with two connectors, later ones in the bottom corners early ones top corners
soz Bruce 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #54542 22nd Jan 2011 5:40pm
kingofthesparks
Location: Very close to Watford gap services , northants
United Kingdom 2012 Defender 90 Puma 2.2 HT Fuji White
Centre connection is earth for both sides i,e two live feeds and one earth that is joined internally to both circuits, Thumbs Up
Post #54543 22nd Jan 2011 5:59pm
Peter Td4
Belgium 2008 Defender 110 Puma 2.4 HCPU Santorini Black
Perhaps best is to measure with a voltmeter the voltage to a known ground point before making the connections.
If your pre-fitted wiring loom only has two connections at the ends and none in the middle I suppose one of these will be ground and the other the positive feed.
Also interesting to know is that the heated front screen is normally powered through a time limited relay which will cut the power to the heating wires after several minutes.
This to prevent continuous operation.
The relay that I bought for this purpose is PRC6796.
Interesting to read : http://forums.lr4x4.com/index.php?showtopic=19100 Peter,
Defender 110 StaWa - Td5
Defender 110 HCPU - Puma
Defender 90 Soft Top - Td5
Post #54645 23rd Jan 2011 12:25am
