![]() | Home > Technical > Defender Front Heated Screen wiring query |
only seen them with two connectors, later ones in the bottom corners early ones top corners
soz Bruce 2.4 90 XS 1968 1/32 scale Britains 109 Pick up. |
kingofthesparks Member Since: 06 Jan 2011 Location: Very close to Watford gap services , northants Posts: 987 ![]() ![]() ![]() |
Centre connection is earth for both sides i,e two live feeds and one earth that is joined internally to both circuits,
Peter Td4 Member Since: 23 Oct 2010 Location: Antwerp, Belgium Posts: 228 ![]() ![]() ![]() |
Perhaps best is to measure with a voltmeter the voltage to a known ground point before making the connections.
If your pre-fitted wiring loom only has two connections at the ends and none in the middle I suppose one of these will be ground and the other the positive feed. Also interesting to know is that the heated front screen is normally powered through a time limited relay which will cut the power to the heating wires after several minutes. This to prevent continuous operation. The relay that I bought for this purpose is PRC6796. Interesting to read : http://forums.lr4x4.com/index.php?showtopic=19100 Peter, Defender 110 StaWa - Td5 Defender 110 HCPU - Puma Defender 90 Soft Top - Td5 |
