Home > Td5 > Fog Light Playing Up!
Qwerty677
United Kingdom 2003 Defender 90 Td5 ST Caledonian Blue
Hi All, for reasons best known to itself, my rear fog lamp has come on and despite my best efforts won't go out! Removing the bulb holder there was some sign of corrosion, so I replaced the bulb holder with a OEM item, no improvement. A thorough dowsing of contact cleaner on loom plug hasn't improved the situation, and finally having identified the correct fuse Number 26 and removed it the light is still on! The Fog Lamp is illuminated on the dash as is the small light on the selector switch. Anyone had something similar or any good suggestions?
Post #542813 23rd Jun 2016 7:25pm
JWL
Towing electrics fitted? If so have a look at them as well as the plug socket tucked up behind the lights in the off side wheel arch whether tow electrics or not.
Post #542829 23rd Jun 2016 8:16pm
Martin
Site Admin
Something is back-feeding the fog lamp from another circuit.
You could try removing then replacing fuses for other circuits to try and work out where the fault lies.
But checking the tow electrics (unplugging them from the grey connector) is a good start.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #543297 25th Jun 2016 12:58pm
