![]() | Home > Td5 > Fog Light Playing Up! |
Towing electrics fitted? If so have a look at them as well as the plug socket tucked up behind the lights in the off side wheel arch whether tow electrics or not.
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6641 ![]() ![]() ![]() |
Something is back-feeding the fog lamp from another circuit.
You could try removing then replacing fuses for other circuits to try and work out where the fault lies. But checking the tow electrics (unplugging them from the grey connector) is a good start. ![]() ![]() |
