Home > Technical > Detachable tow bar Supplier. |
davew Member Since: 02 Jan 2012 Location: North Yorkshire Posts: 888 |
Is that the external or internal measurement ? Sounds like a 2 inch receiver, for which there are loads of options for recovery and towing equipment. http://www.yorkshireoffroadclub.net/
8th Jun 2016 10:34pm |
Bps Member Since: 14 Feb 2016 Location: Lancashire Posts: 825 |
Search receiver hitch on Google and it'll give you some ideas. There are a few people about doing the full kits and I'm pretty sure you can buy the hitch on its own
8th Jun 2016 10:35pm |
muddybaldboy Member Since: 09 Apr 2012 Location: Ruthin Posts: 395 |
http://www.extreme4x4.co.uk/acatalog/QUICK...WBARS.html He who dies with the most toys...wins!
8th Jun 2016 10:42pm |
leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8581 |
2" receivers are not approved as towing equipment. However if it can be used legally or not as tow bar depends if your Defender is pre 97 or is classed as a commercial.
The internal measurement of the tube should be in the region 50.8- 51.0 mm Have a search on 4x4overlander.com for drop plates. Brendan |
8th Jun 2016 11:01pm |
LANDROVER Member Since: 13 Feb 2016 Location: EAST OF ENGLAND Posts: 208 |
Click image to enlarge Click image to enlarge Click image to enlarge This is the dimensions of the receiver. I haven't been able to find anything off the shelf which fits yet? Do you have any other suggestions before I make something. I'm a bit reluctant to make something if something tested and rated is available. Thanks. |
23rd Jun 2016 6:32pm |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6605 |
http://www.abp-accessories.co.uk/product.php?cat=78
http://www.watling-towbars.co.uk/import_vehicle_towbars.html (towards bottom) 1988 90 Td5 NAS soft top 2015 D90 XS SW |
23rd Jun 2016 6:47pm |
Cheers Martin,
I will contact Watling, as you pointed out they will make to spec so hopefully they will make one for me with a drop plate. |
23rd Jun 2016 7:21pm |
