![]() | Home > Technical > Detachable tow bar Supplier. |
davew Member Since: 02 Jan 2012 Location: North Yorkshire Posts: 888 ![]() ![]() ![]() |
Is that the external or internal measurement ? Sounds like a 2 inch receiver, for which there are loads of options for recovery and towing equipment. http://www.yorkshireoffroadclub.net/
Bps Member Since: 14 Feb 2016 Location: Lancashire Posts: 837 ![]() ![]() |
Search receiver hitch on Google and it'll give you some ideas. There are a few people about doing the full kits and I'm pretty sure you can buy the hitch on its own
muddybaldboy Member Since: 09 Apr 2012 Location: Ruthin Posts: 395 ![]() ![]() ![]() |
http://www.extreme4x4.co.uk/acatalog/QUICK...WBARS.html
2" receivers are not approved as towing equipment. However if it can be used legally or not as tow bar depends if your Defender is pre 97 or is classed as a commercial.
The internal measurement of the tube should be in the region 50.8- 51.0 mm Have a search on 4x4overlander.com for drop plates. Brendan |
LANDROVER Member Since: 13 Feb 2016 Location: EAST OF ENGLAND Posts: 216 ![]() ![]() |
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge This is the dimensions of the receiver. I haven't been able to find anything off the shelf which fits yet? Do you have any other suggestions before I make something. I'm a bit reluctant to make something if something tested and rated is available. Thanks. |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6638 ![]() ![]() ![]() |
http://www.abp-accessories.co.uk/product.php?cat=78
http://www.watling-towbars.co.uk/import_vehicle_towbars.html (towards bottom) ![]() ![]() |
Cheers Martin,
I will contact Watling, as you pointed out they will make to spec so hopefully they will make one for me with a drop plate. ![]() |
