Home > Technical > Detachable tow bar Supplier.
LANDROVER
My Land Rover 90 has a welded in square for a detachable tow bar.
I measured it at 58mm square?
Does anyone know of a supplier of a 58mm square tow bar and drop plate.
It looks really well done so image it to be a proper conversion along with other chassis modifications. Roll cage mounts ect. It has a hole to pin the bar in place etc.
If not I will have to make one...just hoped a commerical option was readily available.
Thumbs Up
Post #538728 8th Jun 2016 10:12pm
davew
England 1990 Defender 90 V8 Petrol PU Auto Rioja Red
Is that the external or internal measurement ? Sounds like a 2 inch receiver, for which there are loads of options for recovery and towing equipment. http://www.yorkshireoffroadclub.net/
Post #538729 8th Jun 2016 10:34pm
Bps
Search receiver hitch on Google and it'll give you some ideas. There are a few people about doing the full kits and I'm pretty sure you can buy the hitch on its own
Post #538730 8th Jun 2016 10:35pm
muddybaldboy
Wales 1999 Defender 110 Td5 HT Chawton White
http://www.extreme4x4.co.uk/acatalog/QUICK...WBARS.html Thumbs Up He who dies with the most toys...wins!
Post #538732 8th Jun 2016 10:42pm
leeds
2" receivers are not approved as towing equipment. However if it can be used legally or not as tow bar depends if your Defender is pre 97 or is classed as a commercial.
The internal measurement of the tube should be in the region 50.8- 51.0 mm
Have a search on 4x4overlander.com for drop plates.
Brendan
Post #538735 8th Jun 2016 11:01pm
LANDROVER
This is the dimensions of the receiver. I haven't been able to find anything off the shelf which fits yet? Do you have any other suggestions before I make something. I'm a bit reluctant to make something if something tested and rated is available. Thanks.
Post #542794 23rd Jun 2016 6:32pm
Martin
Site Admin
Post #542799 23rd Jun 2016 6:47pm
LANDROVER
Cheers Martin,
I will contact Watling, as you pointed out they will make to spec so hopefully they will make one for me with a drop plate.
Thumbs Up
Post #542811 23rd Jun 2016 7:21pm
