Home > Puma (Tdci) > Chukka chukka chukka 'click'
rossy
Thats what it does now - normal chukkas followed by a sharp click. It never did that before. Has anyone else had that and is it the sign of impending failure ? After five years of trouble free ownership I'm bracing myself for a plethora of problems (clutch starting to get a bit noisy in neutral too)
Post #537632 5th Jun 2016 8:15am
Roy5695
a loud chucka chucka noise indicates that the EGR is starting to get gummed up, people have had varying degrees of success by removing the EGR and cleaning it, others simply replace for piece of mind. Then again others opt for it to be electronically shut and just the cleaning cycle to remain on to allow freedom of movement of the EGR if it needs to be activated for tighter emissions laws in the future.
Post #537641 5th Jun 2016 8:35am
rossy
sorry I didn't make it very clear - the chukkas were always there (normal and not loud, in fact same tone since new) but the addition of a click at the end of the cycle is the recent thing so I wondered if that could be an issue. Thanks Roy
Post #537646 5th Jun 2016 9:10am
Roy5695
not sure about that one sorry, i had mine replaced under warranty due to the loud chucka chucka. The only real way to see if there is a problem with it would be to have some diagnostics plugged in while running. I have an Ultra gauge which indicates many parameters of the engine, one of which is EGR flow so i can see if it is operating as it should Thumbs Up
Post #537853 6th Jun 2016 8:41am
NinetyTD4
Wales 2012 Defender 90 Other SW Keswick Green
Did you have your car in for service lately? There is a reprogram of the EGR, where you will have a click after the three chakkas. Never forget: cars have owner, Landrover have field service personnel.
Post #537886 6th Jun 2016 11:20am
andydef90
United Kingdom 2014 Defender 90 Puma 2.2 HT Corris Grey
take it off give it a good clean with egr cleaner or brake cleaner iv had this myself but not on my defender its worth a try instead of just forking out for a replacement
Post #537914 6th Jun 2016 12:55pm
rossy
Thanks for the replies
I'll have a go at cleaning it as there is plenty of advice here. As regards servicing, oils and filters are done by me - all oils every year. Thankfully I have found a good indy locally who can do the tricky things !
Post #537986 6th Jun 2016 5:48pm
