![]() | Home > Puma (Tdci) > Twang when closing passenger door |
Is the nylon cover still on the striker? Ray
Noiseydave Member Since: 27 Dec 2015 Location: West Midlands Posts: 43 ![]() ![]() ![]() |
good point, just checked, yes it is and looks in good condition.
Anderzander Member Since: 08 Feb 2011 Location: Lancashire Posts: 1000 ![]() ![]() |
Is the hinge starting seize?
N16kct Member Since: 24 Aug 2015 Location: Oxfordshire Posts: 151 ![]() ![]() ![]() |
Nut loose on the check strap? I know it's not meant to be tight, tight, but mine started to back off which meant there was excessive play, resulting in a twang followed by a crack as it fully extended and the side of the hole hit the thread of the bolt.
o4dn Member Since: 08 Jan 2010 Location: South West Posts: 555 ![]() ![]() ![]() |
The window sliding gutter is held by a small self taping screw at the bottom, mine got loose and the entire mechanism was rattling inside the door just like you described.
Design to last... sigh. “A Land Rover immobilized is a moral defeat for the driver and bad publicity for the vehicle, […] it's up to you to do justice to your Land Rover!” - Land Rover Driving Technique. -- 2009 2.4 Puma Defender 90 SW 1979 Land Rover Series 3 88" |
Thanks 04dn
I am going to open it up again this weekend Dave |
Hi Anderzander , N16kct
Thank you for the input, hinge looks and feels ok and i removed the check strap and it was the same noise. Dave |
thor44 Member Since: 18 Sep 2015 Location: Ahrntal, Sdtirol Posts: 128 ![]() ![]() |
I had the same on mine. There was a little guidance for the door closing mechanism sticked to the inside of the door (you have to remove the door panel and the black cover on the inside). The glue came off and caused the metal rod it should hold in place to bang to the door every time the door was closed. The easy fix was to take a piece of double-sided tape and stick it back on. . _____
.|_____\___ [|_/-\__/-\_|} ...(O)....(O)........ MY14 2.2 Defender 90 SW |
