Home > Puma (Tdci) > Twang when closing passenger door
Noiseydave
United Kingdom 2009 Defender 110 Puma 2.4 XS DCPU Santorini Black
Hi,
When I close the passenger door on my 2009 DC there's is a metallic twang/rattle from inside the door. I have removed the door card and the interior pull to lock connector bar and it is is still making the noise. Everything else is tight and no signs of anything touching, any thoughts or advice where to look?
Dave
Post #535622 29th May 2016 12:32pm
mk1collector
Is the nylon cover still on the striker? Ray
My build thread
Post #535639 29th May 2016 2:21pm
Noiseydave
good point, just checked, yes it is and looks in good condition.
Post #535646 29th May 2016 2:35pm
Anderzander
Is the hinge starting seize?
Post #535649 29th May 2016 2:46pm
N16kct
United Kingdom 2010 Defender 110 Puma 2.4 USW Corris Grey
Nut loose on the check strap? I know it's not meant to be tight, tight, but mine started to back off which meant there was excessive play, resulting in a twang followed by a crack as it fully extended and the side of the hole hit the thread of the bolt.
Post #535840 30th May 2016 12:24pm
o4dn
France 2009 Defender 90 Puma 2.4 SW Alaska White
The window sliding gutter is held by a small self taping screw at the bottom, mine got loose and the entire mechanism was rattling inside the door just like you described.
Design to last... sigh. “A Land Rover immobilized is a moral defeat for the driver and bad publicity for the vehicle, […] it's up to you to do justice to your Land Rover!” - Land Rover Driving Technique.
2009 2.4 Puma Defender 90 SW
1979 Land Rover Series 3 88"
Post #535848 30th May 2016 12:53pm
Noiseydave
Thanks 04dn
I am going to open it up again this weekend
Dave
Post #535850 30th May 2016 1:03pm
Noiseydave
Hi Anderzander , N16kct
Thank you for the input, hinge looks and feels ok and i removed the check strap and it was the same noise.
Dave
Post #535852 30th May 2016 1:07pm
thor44
2014 Defender 90 Puma 2.2 SW Indus Silver
I had the same on mine. There was a little guidance for the door closing mechanism sticked to the inside of the door (you have to remove the door panel and the black cover on the inside). The glue came off and caused the metal rod it should hold in place to bang to the door every time the door was closed. The easy fix was to take a piece of double-sided tape and stick it back on. . _____
.|_____\___
[|_/-\__/-\_|}
...(O)....(O)........ MY14 2.2 Defender 90 SW
Post #536164 31st May 2016 3:22pm
