Home > Td5 > clicking noise
yanto
Wales
clicking noise
Hi all
There is a clicking noise when changing from 5th to 4th. It even does it if it are stationery with the engine off. Almost sounds like an electric shock?
Just started today.
Any ideas?
Post #535183 27th May 2016 4:26pm
grumpy old git
I'd say that's the bias spring clicking against the bias plate, nothing to worry about. Nearly necessitated a gearbox strip down on my first Td5.....
Post #535190 27th May 2016 5:01pm
yanto
Wales
Thanks bud. How can I stop it?
Post #535196 27th May 2016 5:36pm
It will be the latch that prevents you inadvertently changing from 5th to reverse resetting itself. It is a normal feature of the R380 box.
I had exactly the same question when I bought my TD5 Disco.
Post #535208 27th May 2016 6:13pm
miker
Mine is an Ashcroft rebuild from December and does it. Never investigated it but always assumed it was a bias plate/springy thing moving.
Post #535216 27th May 2016 6:33pm
yanto
Wales
Thanks guys. Any idea why it has just started doing it? Had the landy 2 weeks and before it was fine. Can it be fixed? It's very irritating?
Post #535220 27th May 2016 6:57pm
yanto
Wales
Also,how do you access it? Through the gate?
Post #535221 27th May 2016 6:59pm
Fatboy Slim
Wales
I'd be more worried if it didn't do it. It's meant to. To get access to it you need to remove the gearbox and strip out the rear housing.
Post #535243 27th May 2016 8:03pm
yanto
Wales
Thanks guys. I'm probably not explain it properly. It sounds like an electric arc? I have had the truck 2 weeks and it didn't do it when I bought it?
Post #535353 28th May 2016 10:04am
DefenderJon
Northern Ireland 2000 Defender 90 Td5 CSW Epsom Green
That click is definitely an inbuilt design to prevent you going from 5th to reverse. Is it possible that, in the first two weeks of ownership you just didn't notice it, but now that you're aware of it, it's more noticeable? Be assured, it SHOULD do it.
Jon. Defender 90 TD5 CSW - The longer I own it, the newer it gets!!
Post #535363 28th May 2016 12:20pm
