Home > Td5 > clicking noise |
grumpy old git Member Since: 16 Nov 2013 Location: United Kingdom Posts: 153 |
I'd say that's the bias spring clicking against the bias plate, nothing to worry about. Nearly necessitated a gearbox strip down on my first Td5.....
27th May 2016 4:01pm |
yanto Member Since: 03 Sep 2009 Location: caerleon Posts: 230 |
Thanks bud. How can I stop it?
27th May 2016 4:36pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17361 |
It will be the latch that prevents you inadvertently changing from 5th to reverse resetting itself. It is a normal feature of the R380 box.
I had exactly the same question when I bought my TD5 Disco. |
27th May 2016 5:13pm |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1763 |
Mine is an Ashcroft rebuild from December and does it. Never investigated it but always assumed it was a bias plate/springy thing moving.
27th May 2016 5:33pm |
Thanks guys. Any idea why it has just started doing it? Had the landy 2 weeks and before it was fine. Can it be fixed? It's very irritating?
27th May 2016 5:57pm |
Also,how do you access it? Through the gate?
27th May 2016 5:59pm |
Fatboy Slim Member Since: 04 Feb 2008 Location: Bridgend Posts: 1006 |
I'd be more worried if it didn't do it. It's meant to. To get access to it you need to remove the gearbox and strip out the rear housing.
27th May 2016 7:03pm |
Thanks guys. I'm probably not explain it properly. It sounds like an electric arc? I have had the truck 2 weeks and it didn't do it when I bought it?
28th May 2016 9:04am |
DefenderJon Member Since: 01 Dec 2012 Location: Sunny Ulster Posts: 68 |
That click is definitely an inbuilt design to prevent you going from 5th to reverse. Is it possible that, in the first two weeks of ownership you just didn't notice it, but now that you're aware of it, it's more noticeable? Be assured, it SHOULD do it.
Jon. Defender 90 TD5 CSW - The longer I own it, the newer it gets!! |
28th May 2016 11:20am |
