Home > Maintenance & Modifications > wiring help with my rear camera and lights on. |
Lancerdoc999 Member Since: 10 Apr 2016 Location: South Wales Posts: 205 |
I'm no wiring wiz but looking at the wiring diagram the reversing light and rear side tail/stop lights seem to share the same earth. Could this have anything to do with it?
25th May 2016 9:44pm |
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3720 |
I'm like you not sure with wiring
Any idea how I overcome this? Thanks |
25th May 2016 9:50pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20121 |
With the sidelights on there would be draw on the rear earth as the number plate light and rear tail lights etc would be on.
The reverse ads to it, the front would be a different matter due to different earth. That could be the issue, check the earth strap on the transfer box rear clean and tighten and see if that cures your issue. If you've had any drivetrain work completed lately then there is even higher likelyhood of earthing issues. Reason the earthing is a common fault is because it has random effects on various circuits. Once when it was loose on mine, the same earth I mentioned above if you'd brake the indicators would all flash end the whole dash, I mean every light light would light up. Indicate right, left indicators would work instead etc. You should check earth continuity, before anything at reverse lights etc and you should be able to determine the issue without getting under first with a Multimeter. Last edited by custom90 on 26th May 2016 12:35am. Edited 1 time in total |
25th May 2016 10:00pm |
In lieu of a multimeter, open up your battery compartment, from the neg terminal you'll see a fat cable exit via a grommet towards the centre of the vehicle. Get under and have a look around the transfer box where this cable exits, see if it's secure. Solved the bowel problem, working on the consonants...
26th May 2016 12:01am |
