Home > Maintenance & Modifications > Airbox and drain holes photos
Just thought I would ad these up here for people's reference, if your adding a Snorkel you'll have to seal these joints and drain holes to make it watertight.
You can also see the airbox mod too.
Hope someone may find these useful at some point!
Thumbs Up
Not all photos are of drain holes but just airbox related stuff, good for a look before starting any jobs.
Post #534069 23rd May 2016 7:35pm
LoveTheMud
United Kingdom 2014 Defender 90 Puma 2.2 XS CSW Santorini Black
Good pics! It's something I need to do.
This may also be useful to some:
https://www.firstfour.co.uk/item/2176798/d...ystem--rhd
Post #534085 23rd May 2016 8:27pm
jomara
Scotland 2014 Defender 110 Puma 2.2 XS CSW Santorini Black
Hi Steve
Do you find any difference with the air box opened out? 2014 110 2.2TDCi XS Station wagon
1971 Bowler Tomcat 88 4.2 V8 Auto
2022 110 D250 XS Edition - Gone
2024 110 D250 X-Dynamic HSE
Post #534089 23rd May 2016 8:37pm
LoveTheMud - Link doesn't work for some reason? Maybe, it's me on iPad as I've had issues with FF links before for some bizarre reason. Confused
Jommara - Yes, I have noticed a difference, more oomph off the mark.
Nothing to get excited about but there's definitely a pick up in revs and turbo quicker than before.
I did the mod ages ago, made an improvement but couldn't finish it properly without taking the whole box out which I didn't do.
The last few days whilst it was out I finished that off to whilst at it.
Some will argue it makes no difference, I think it does.
I took out the rain separator and the sections you can see, Dremel hot knife on soldering iron did the trick.
Mind you outside only! Toxic fumes to be avoided. Shocked
There are other solutions for sealing the pipe work, such as that from D44, nugget stuff etc.
But costs more and more and more and I haven't got days to spend on it so I'm happy enough as is myself.
Fitted my Safari snorkel now, all good. Nearly got caught out by the damn top nut access.
Luckily I had an extension bar with the sealant wet.
Otherwise I'd have been in a sticky situation!
The drain hole with the rubber bung in I never even knew was ever there.
I've sealed the lot on mine bar the one drain hole, the smaller one in the bottom of the airbox.
Post #534097 23rd May 2016 8:51pm
LoveTheMud
Checked the link, it works but is taking a while to load...
Did you do anything to the engine electrics or the accelerator pedal?
I have a 2.2 and have been told that no matter what I do, water will wreck the engine even with a sealed RAI/Snorkel - I still want to try through Thumbs Up
Post #534127 23rd May 2016 10:00pm
No I didn't, don't intend to wade it.
However, I like to know it's there if I needed it, there's breathers etc but I doubt I'll ever do that.
Main likelyhood would be water splash up the side, which it would prevent.
Also stops dirt and rubbish coming in through some of the drain holes.
One day I might buy a rubber bung for the airbox bottom, and keep in in my 90. That way most the time I could keep it out and if ever it was needed could just put it in
I've mainly done the sealing to do the job once, and do it properly rather than seeking a 100% sealed set up.
You've got to bear in mind it's a good idea to still keep one drain hole in or you could create a drain of the whole thing making the airbox like a fish tank. Shocked
At least now it's all sealed I know where the only drain hole will be and its accessable. (Well as best as you'll get.)
Like you say, I agree same for mine but you like me still want to do the job properly.
It is at least better and more protected and will,never be a boat.
Thumbs Up
Thumbs Up
Post #534138 23rd May 2016 10:24pm
