Home > Puma (Tdci) > Indicators Don't Flash on locking |
Cat81 Member Since: 05 Mar 2014 Location: Kent Posts: 60 |
Mine had that problem - was a simple fuse behind offside front speaker.
23rd May 2016 8:44pm |
read the owner manual.
not flash = remote battery low Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
24th May 2016 7:46pm |
yorkshireman Member Since: 28 Mar 2016 Location: North England Posts: 80 |
Hi, yes I've changed the battery in the fob. I'll see if it's a fuse.
24th May 2016 8:05pm |
After a Fob battery change you may need to resync it:
>> Push lock 4 times then unlock It'll be unresponsive until the unlock. Hopefully that's all it is. Solved the bowel problem, working on the consonants... |
24th May 2016 8:25pm |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1762 |
My TD5 (Same alarm I believe) Only flashes 1 side, 95% of the time. Every so often, both sides flash. Both fobs are the same, and it's not a battery issue as it never flashed at all until I replaced the fob battery!
And yes, indicators and hazards work fine. |
24th May 2016 9:04pm |
Yip, same 10AS unit in TDCi and TD5.
The battery replacement thing seems random with my vehicle, I only discovered it the last time I did a swap, about 4 replacements prior never had the issue. I also had an intermittent indicator repeater, that decided to operate with no apparent rhyme or reason, suspect it was a corroded connection... Fuse sounds likely, if it's all of them. Actually, should ask: do the indicator 'indicators' (in the dash) light up? Solved the bowel problem, working on the consonants... |
24th May 2016 9:31pm |
Ok turns out the fuse under the drivers seat for the alarm was missing altogether, the previous owner had dogs so probably a simple solution to disabling the sensors but not the locking. Fuse in and all is working fine, indicators flash and alarm triggers as it should. Thanks for all the suggestions.
4th Jun 2016 3:29pm |
