Home > Off Topic > Patriot/Hannibal rack deterioration! |
BigRuss Member Since: 15 May 2010 Location: Norfolk Posts: 2785 |
Well tbh you're never gonna get away from bi-metal corrosion.
no mater whether you get a Hannibal or a Patriot rack (both made from ali) you'll always find some steel fixings. Russell 2011MY 110 XS USW Black |
15th Jan 2011 6:02pm |
Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 5013 |
Oh . Isn't there some special stuff you can put on the fasteners to make a barrier between the two metals to prevent or reduce the reaction. I presume the racks are delivered in kit form so owners could do it themselves.....
15th Jan 2011 6:18pm |
mick Member Since: 08 Feb 2010 Location: Yorkshire Posts: 2109 |
See if you can get a bare ali one and get it powder coated yourself some of the coatings you see are so thin they wont stand any knocks or scrapes
15th Jan 2011 6:44pm |
Defender SVX Member Since: 29 Jan 2009 Location: Co Durham Posts: 730 |
I would imagine if you assembled it and coated the stainless Allen fasterners with copper slip combined with regular cleaning it will be fine maybe even a quick rub over with some wax polish now and again.
That's what I did with the chequer plate on the 110 dcpu when it came the plate had been fitted by the first owner but after last winter the salt had started the reaction causin unsightly streaks down the sills I stripped them all off cleaned and waxoyled the body sills cleaned and waxed the chequer sills then refitted coating the Allen bolts with copper slip. This time after the salt there is some marks but it easily washes off with soap and warm water. Formerly mao99999 16 Focus RS Nitrous Blue. 11 FFRR TDV8 Vouge SE Black Black. 08 DEFENDER SVX SOFT TOP (SUPERB) 08 DEFENDER 110 DCPU Stornoway grey (Overland Exploration Unit) 05 Fiesta ST 150 Van 04 Jaguar XKR 4.2 Supercharged V8 02 DEFENDER 90 TD5 (next years soft top project) 95 DEFENDER 110 CSW 300 TDi Phoenix black 95 DEFENDER 90 HT Monti Carlo blue COUNTY 300 TDi 67 109" SERIES 2a TUNED 200 TDI 64 DAVID BROWN 990 rat look 55 86" SERIES 1 |
15th Jan 2011 6:52pm |
Michael Brindley Member Since: 07 May 2008 Location: stoke-on-trent Posts: 85 |
Had a Hannibal rack on a Defender from Rogers of Bedford many years ago the Landrover was a 2000 110csw TD5 and about 12 months old the rack was new because at the time they were agents.The rack was natural bare aluminium but the roof clamps were stainless.After about 18 months the rack looked a bit tatty after the weather and slt got to it.The swapped to a new 2004 defender and swapped the rack to it but had it blasted and powder coated by a company called Redditch Shotblasting and powder coating then had a Puma in 2007 which have still got and the rack is fitted to this.I use the Landrover as a working vehicle it carries ladders,steps, trunking ets and occasionally a couple of 6m lighting coloums.I also on occasions use it as a mobile platform for working off.The rack is still in perfect condition as there is no steel to rust.Recently i was talking to Nene Overland at a show and saw that there newer rascks had a rubber strip in the roof rail between the rack and rail.They very generously sent me the rubber free of charge in the post.I have also put some thin rubber sheet between the clamps and the roof just to protect the paint.Probably the best purchase ever made on a Defender.Patriots werent around at the time so i dont know about them.Its now 9 years old and if i sold it tomorrow would probably get a good price for it.Any doubts speak to Nene Qverland they are very good.
15th Jan 2011 7:13pm |
kingofthesparks Member Since: 06 Jan 2011 Location: Very close to Watford gap services , northants Posts: 987 |
not sure you would want to use copper slip, adding another metal to the mix might not be wise...
15th Jan 2011 7:15pm |
Thanks for your replies. There is something they use for yachts as quite a bit of aluminium is used on them. I have to find out what it is anyway as I need to replace steel screws in my aluminium mast. I will post the name of it when I have found out
15th Jan 2011 8:46pm |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 |
DURALAC is what I use on my boats and my Landy when using dissimilar metals |
15th Jan 2011 9:02pm |
Excellent thanks for that Quicker than the sailing forum (who gave same answer)
15th Jan 2011 9:07pm |
willy eckerslike Member Since: 15 Jun 2009 Location: North yorks Posts: 1789 |
Which number of racks and where are you seeing them,
Where are you hanging out that all the defenders have racks. Why are the aluminium racks you've "seen" painted. Do you have a roof rack. Are you related to discotres. Have you nothing better to do than talk Original Member Pie n Pea Club. 110 HCPU Tipper |
15th Jan 2011 9:24pm |
TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3750 |
Ditto, as used here, in this case, stainless bolts into a alloy toe rail California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
15th Jan 2011 10:45pm |
BIGFOG Member Since: 12 Sep 2010 Location: Edenbridge Posts: 537 |
Somewhat off topic but, lots boaty people here, what do you all sail?? I have a Formula 18 catamaran that goes loony fast, but has nowhere to pour a G&T...
15th Jan 2011 11:06pm |
All 10 tones of a blond Swede California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
15th Jan 2011 11:26pm |
Sister has a Cat - sooo quick! I envy your speed I have a Folksong 26. Can pour a beer but bang my head 4' 10" head room Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Last edited by Zagato on 16th Jan 2011 9:55am. Edited 1 time in total |
16th Jan 2011 9:49am |
