Home > Puma (Tdci) > Squealing brakes
Fozzauk
United Kingdom 2016 Defender 130 Puma 2.2 HCPU Santorini Black
Squealing brakes
The 130 has been back to the dealers twice now for the brakes squealing and each time the squeal is even worse than before after a few miles driving. It has gotten to the point now where they are literally screaming when I touch the pedal and it is driving me mad! Even the attendant at the local shell garage comments " I know when you have pulled up!" Embarassed
Anyone else had a resolution to this?
I am getting to the point where I am going to fix this myself but I don't see why I should have to on a new car under warranty!
Post #530887 12th May 2016 8:54am
dorsetsmith
stones between bake discs and the stone shelled or pads fitted wrong way round i.e. with leading of the pad upside down and with out copper grease
also if your not happy with the service proved by your garage try new garage
Post #530899 12th May 2016 9:17am
Disco_Mikey
Scotland 2009 Defender 110 Puma 2.4 DCPU Keswick Green
My 110 was screaming like a Censored
Had a seized piston in one of the rear calipers. Freed off, clean and grease the pads, and all sorted Thumbs Up
Post #530904 12th May 2016 9:22am
Fozzauk
They are usually pretty good at resolving things but I can't see how many times they can strip and rebuild the brakes and expect a different result to the last time?
Surely a piston shouldn't have seized on a 6 month old defender! Actually it is a land rover after all Big Cry
The squealing seems to be at its worst when I have been on the motorway for a while and then come off to stop on the slip road.
Post #530908 12th May 2016 9:42am
dorsetsmith
brake pads stinking in the calipers witch is made weirs by heat i.e. thermal expansion. i had set of pads squealing, the only way i stopped the squealing removed the pads and fitted new set. old set no more than one mouth old from LRJ
Post #530922 12th May 2016 10:14am
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
Can you see if they have put copper grease on the pad backs? 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #530933 12th May 2016 10:41am
Fozzauk
After the last visit everything was covered in copper grease! Apart from the pad surfaces!
Post #530935 12th May 2016 10:50am
ian series 1
Do 130s have a brake bias fitted? 80" 80" 86" 88" 90"
Post #530940 12th May 2016 10:59am
wyvern
United Kingdom 2012 Defender 110 Puma 2.2 XS CSW Firenze Red
I had this after my last service and it turned out to be the break pads at fault - they were too hard a compound so squealed for about 2000 miles till I had them changed for new Landrover original parts and hay presto - all better and normally returned - as did better breaking and less dust!!
The pads used first time where after market ones and the same ones as I’ve been having fit for years - so no idea if they have changed their compound ... but now all sorted
Thumbs Up Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html
Elgar -TDCI(Puma) 110XS Dormobile - now sold
Devon & Cornwall 4x4 Response - DC126
Post #531010 12th May 2016 3:47pm
