![]() | Home > Td5 > cutting out and water guage jumping into the red |
huffhuff Member Since: 05 May 2016 Location: Home Counties Posts: 379 ![]() ![]() ![]() |
Think I already replied to your Facebook thread. Run a new earth, check ECU plugs and relays for corrosions and ensure they're making good contact
gazman Member Since: 17 Aug 2015 Location: Liverpool Posts: 652 ![]() ![]() ![]() |
yes you have mate. I was talking this through with a colleague at lunch and he told me to post the same question on a forum over Facebook as he said forums tend to be more knowledgeable.
I'm with you though, but just incase it's a common fault and as I'm going to be doing it on the high street at 7pmm I front of all the pubs and drinkers I want it sorted as quick as I can! 2014 - current ..... 2003 defender td5 90 (my car) 2009 - current .... 2005 zx10r |
I find Facebook good for a quick response...
...forum best for a more thoughtful, sometimes more accurate response ![]() |
landroverdiver Member Since: 13 Jun 2009 Location: Renfrewshire Posts: 193 ![]() ![]() |
Same thing happened to me, it was oil in ECU plug
Steve Sidebottom Member Since: 09 May 2016 Location: Derbyshire Posts: 2 ![]() ![]() ![]() |
This happened on my old TD5, one of the yellow relay under the drivers seat had poor contacts. A clean with contact cleaner and a squeeze of the slot terminals and all was good again.
looks like your bang on the money Steve. I relocated my fuse box and ecu from under the drivers seat, everytime I knocked or moved the main relay the fault occurred.
cleaned the contacts and squeezed them and all is good again 2014 - current ..... 2003 defender td5 90 (my car) 2009 - current .... 2005 zx10r |
double post..... 2014 - current ..... 2003 defender td5 90 (my car)
What I said in the first reply then
you get the smug satisfaction of knowing you were right, and the double factor of knowing that I then didn't quote you as being the 1st correct one! 2014 - current ..... 2003 defender td5 90 (my car)
Well I'll PM you my email and you can send me some Amazon vouchers or something
![]() Glad you got it sorted... Fingers crossed it wasn't one of those annoying intermittent issues |
if I ever bump into you their is a pint or two on me
![]() 2009 - current .... 2005 zx10r |
