Home > Td5 > cutting out and water guage jumping into the red |
huffhuff Member Since: 05 May 2016 Location: Home Counties Posts: 379 |
Think I already replied to your Facebook thread. Run a new earth, check ECU plugs and relays for corrosions and ensure they're making good contact
6th May 2016 1:34pm |
gazman Member Since: 17 Aug 2015 Location: Liverpool Posts: 652 |
yes you have mate. I was talking this through with a colleague at lunch and he told me to post the same question on a forum over Facebook as he said forums tend to be more knowledgeable.
I'm with you though, but just incase it's a common fault and as I'm going to be doing it on the high street at 7pmm I front of all the pubs and drinkers I want it sorted as quick as I can! 2014 - current ..... 2003 defender td5 90 (my car) 2009 - current .... 2005 zx10r |
6th May 2016 1:56pm |
I find Facebook good for a quick response...
...forum best for a more thoughtful, sometimes more accurate response |
6th May 2016 2:01pm |
landroverdiver Member Since: 13 Jun 2009 Location: Renfrewshire Posts: 193 |
Same thing happened to me, it was oil in ECU plug
6th May 2016 2:13pm |
Steve Sidebottom Member Since: 09 May 2016 Location: Derbyshire Posts: 2 |
This happened on my old TD5, one of the yellow relay under the drivers seat had poor contacts. A clean with contact cleaner and a squeeze of the slot terminals and all was good again.
9th May 2016 2:21pm |
looks like your bang on the money Steve. I relocated my fuse box and ecu from under the drivers seat, everytime I knocked or moved the main relay the fault occurred.
cleaned the contacts and squeezed them and all is good again 2014 - current ..... 2003 defender td5 90 (my car) 2009 - current .... 2005 zx10r |
9th May 2016 5:45pm |
double post..... 2014 - current ..... 2003 defender td5 90 (my car)
9th May 2016 5:48pm |
What I said in the first reply then do I get a prize?!?
9th May 2016 5:51pm |
you get the smug satisfaction of knowing you were right, and the double factor of knowing that I then didn't quote you as being the 1st correct one! 2014 - current ..... 2003 defender td5 90 (my car)
9th May 2016 7:37pm |
Well I'll PM you my email and you can send me some Amazon vouchers or something
Glad you got it sorted... Fingers crossed it wasn't one of those annoying intermittent issues |
9th May 2016 8:04pm |
if I ever bump into you their is a pint or two on me 2014 - current ..... 2003 defender td5 90 (my car)
9th May 2016 8:28pm |
