Home > Puma (Tdci) > Replacing TDCI engine with TD5 engine.
Page 1 of 3 123>
chrisbowler
Has anyone come across/ heard of anyone replacing the TDCi engine in a Puma with a TD5 engine?
Chris Bowler
Post #526810 26th Apr 2016 12:08am
miker
Sounds like a worse idea than just buying a TD5 defender!
Post #526815 26th Apr 2016 12:46am
The td5 engine is a master piece and the foibles are known and fixable, physically it will fit but you'll have challenges around the electronics for the dash, abs etc
Post #526817 26th Apr 2016 5:50am
ibexman
TD5 last of the GREAT Land Rover engines Thumbs Up Thumbs Up
Post #526842 26th Apr 2016 8:42am
Jukathy
2012 Defender 110 Puma 2.2 SW Keswick Green
TDI would be clever.
Good cars are avaible.
Just buy one.
Post #526845 26th Apr 2016 8:59am
It's probably no harder that fitting a Puma bulkhead and dash in a TD5, but you'd need to change the engine and gearbox complete*.
The problem, as with fitting a Puma dash in a TD5, would be that the CanBus IPAC won't work with the TD5 ECU. If you fitted a TD5 instrument panel in place of the TDCI panel you could avoid this problem.
* No point leaving the GFT MT982 box in since the ratios would be wrong (low first probably dangerously so without idle jack) and arguable the output adaptor shaft is the single biggest flaw in the TDCi design. So although the MT82 itself is a much better engineered box and nicer to drive that the TD5's awful 5-speed, it would probably have to go.
Post #526847 26th Apr 2016 9:05am
epictrail
United Kingdom 2004 Defender 110 Td5 HT Chawton White
Can't use the 6 speed box on a TD5. Ashcrofts tried to make it work and I was told couldn't
Post #526851 26th Apr 2016 9:54am
Super7
United Kingdom 1999 Defender 90 Td5 CSW Rutland Red
and I was thinking about putting a TDi in my TD5!
Post #526856 26th Apr 2016 9:59am
Fatboy Slim
Wales
Why would you want to do that? I like the tdis but the 5 is better in every way
Post #526860 26th Apr 2016 10:19am
I like this thread!!!!
If you fit a td5, you need to take a recip saw to the bulkhead vent blanks...to make the Puma a 'proper' Land Rover Razz
Post #526874 26th Apr 2016 11:37am
Only 2 benefits I can think of that the TD5 has. (I've never driven one mind you)
Is the sound is sweet, and it's 5 pot.
Post #526892 26th Apr 2016 12:30pm
jst
Chris - complete with td5 box? Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #526897 26th Apr 2016 12:36pm
Cupboard
Another is the vents, they're great.
Post #526900 26th Apr 2016 12:41pm
Fatboy Slim
Wales
And more economical
Faster
Has MEUI fuel injection
Has a timing chain instead of a poxy belt
Can produce V8 killing performance easily
Dead simple to work on
Has a decent cooling system
I'm on my 9th, also look after several site vehicles that never see a road and also own a 200 and 300. Had several Tdis of my own, and a 2.4 but as an all rounder the Td5 is without a doubt the king.
Post #526904 26th Apr 2016 12:50pm
Super7
My comment was half tongue-in-cheek, but a simpler, cheaper to repair engine does appeal sometimes.
Post #526916 26th Apr 2016 1:09pm
Page 1 of 3 123>
