Home > In Car Electronics > Questions about auxiliary wiring from the battery box
flyingfab
France 2015 Defender 90 Puma 2.2 XS CSW Indus Silver
Hello,
I'm on the verge of installing an auxiliary wiring onto my Defender 90 (MY2015) to feed some accessories in the back. So, I would have a few questions Wink
A) Since I don't want to drill any hole, my intention is to run the cables through one of the holes already in place on the top of the seatbox, just under the left hand seat (the one with a hard cap - number 1 on my picture)
So, I would like to swap it for as a rubber grommet and I'm wondering which LR part reference to order (like the number 2)
B) I have bought this :
Which kind of spacer should I use to make sure the electrical contact is and stays perfect ?
C) I think I will attach the lead loom directly to the battery ... but, just in case, would you recommend another good earthing point, preferably near the battery box (without drilling) ?
Many thanks in advance ! Very Happy
Cheers,
Fabien
PS. I am curious about the thin and soft cap (number 3). Is it supposed to tear off in case of overpressure due to a battery problem ?
Post #526050 22nd Apr 2016 6:00pm
dorsetsmith
seatbox grommets (269257) that fit into the existing 25mm hole
Post #526068 22nd Apr 2016 7:00pm
flyingfab
That's great, thanks a lot ! I didn't expect to get an answer to (the most important of) my questions that fast Thumbs Up
Post #526078 22nd Apr 2016 8:16pm
