Home > Maintenance & Modifications > The definitive wheel and tyre thread..HOW THEY LOOK
Page 30 of 42 <123 ... 293031 ... 404142>
Lambley
United Kingdom 2006 Defender 90 Td5 HT Java Black
GREENI wrote:
@Lambley...very nice! good choice!
Cheers Greeni, they might not be to everyones taste but they're a little wider and the offset is just about perfect for the arches, not too dissimilar to boosts but just 'different' enough. The dark grey suits black, and I've lacquered them in matt to take away the bling factor.
Post #516538 21st Mar 2016 7:25pm
Wild Card 90
England 2012 Defender 90 Puma 2.2 SW Indus Silver
There are probably enough ZU�s somewhere amoungst the 30 pages, but here is another combination.
Gloss black 7x16 ZU�s, 255/85 MT�s, 30mm spacers.
 1998 Tdi 90 SW,
2008 Td4 90 SW,
2012 2.2 90 SW,
2" raised Trailmaster/Terrafirma
Heavy Track Raids, 255 MT�s,
Recaro CS�s, anorak, wellingtons
Post #516542 21st Mar 2016 7:44pm
CarMan
CarMan wrote:
bpman wrote:
Satin Black ZUs with 235/85s
Just what I wanted to see, where's your pic?
BPMan - the pic is missing?
Post #518225 27th Mar 2016 4:06pm
Simon.pl
Poland 2007 Defender 110 Puma 2.4 HT Keswick Green
Has anyone tried 15" x 10" Challenger 5 Spoke -35 steel wheels? Any opinions?
Post #518644 28th Mar 2016 9:19pm
Arierep
Portugal 1995 Defender 90 300 Tdi SW Alpine White
-35 offset? Makes my wheel bearings cry just from thinking about it
Post #518784 29th Mar 2016 10:19am
Lucifus
I'm running 16x10 with a -35 offset on my green 110. You'll certainly need extended arches with that width and offset.
Post #518791 29th Mar 2016 10:47am
familymad
Who makes that RAI? 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #518795 29th Mar 2016 10:58am
Disco_Mikey
Scotland 2009 Defender 110 Puma 2.4 DCPU Keswick Green
18" Boost alloys, 30mm spacers, 285/60 Cooper Zeon LTZ Thumbs Up
Post #518810 29th Mar 2016 11:56am
Simon.pl
@Jose.Pereira - I've seen many options here with the spacers and different offsets. 30mm spacer is like -30 offset for the bearing - the wheel goes outside - correct? So I don't see any particular reason this should not work.
Extended arches - I agree. I quite like them Cool
Thumbs Up
Post #518830 29th Mar 2016 12:56pm
Lucifus
Yes a 30mm spacer on a 0 offset wheel gives the same result as a -30 offset wheel.
Post #518833 29th Mar 2016 1:05pm
Arierep
Thumbs Up
Yes, that's right. But spacers are usally used with wheels with a +33 offset, resulting in a +3mm OS.
Anyway, even a -50mm offset will work, but I'm not sure of the effects of that on wheel bearings. The farther you go from the centerline between the 2 hub bearings the worse it is. How worse and how far, I don't know. But for remote overlanding I would not risk it, of maybe top it at 0mm offset. Maybe a 90 with a lighter gross weight (2550kg) can get away with a wider stance.
Anyway, without any objective study, this is all BS
Post #518854 29th Mar 2016 2:11pm
Wild Card 90
familymad wrote:
Wild Card 90 wrote:
Who makes that RAI?
Nakatanenga....
https://www.nakatanenga.de/fahrzeugtechnik...-ansaugung
You can get it through Brendan.
It runs through round constant diameter tube, all the way to the air filter. Supposed to be very efficient. 1998 Tdi 90 SW,
2008 Td4 90 SW,
2012 2.2 90 SW,
Post #518863 29th Mar 2016 2:38pm
Arierep
Where goes the heater intake?
Post #518883 29th Mar 2016 3:47pm
Wild Card 90
The intake for the heater is the fixed flap on the side. It acts as a scoop, and at the same time saves the need for a snow cowl. All part of the RAI kit. On a RHD its not required as the heater intake is on the other side.
Wasn�t this a thread about wheels Whistle ? 1998 Tdi 90 SW,
2008 Td4 90 SW,
2012 2.2 90 SW,
Post #518929 29th Mar 2016 5:38pm
Arierep
You'r right, too much OT.
Let's meet here:
http://www.defender2.net/forum/topic45263-15.html
Post #519002 29th Mar 2016 7:22pm
