Home > Puma (Tdci) > Here we go again...
pumaxs
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Zambezi Silver
Here we go again...
...and this time i'm quite worried.
Driving back from walking the dog, last night.
Got about a 1/4 of a mile from home when loud knocking noise started coming from engine bay.
All gauges reading normal & no warning lights illuminated.
It was getting dark, and the weather was going down hill, so I just parked up and left it overnight.
Anyway, had a look this morning & checked oil + coolant levels (both normal) before starting engine up.
All hopes of a miraculous overnight recovery were instantly dashed.
There is a loud knocking sound coming from the top of the engine, which gets louder + faster with application of throttle.
There are still no warning lights showing on dash.
Tick over is lumpy, but not clouds of smoke coming from exhaust.
RAC have been out & plugged in diagnostics, but there are no fault codes being displayed.
So, will have to wait for garage to open & get recovered tomorrow.
Not sure whether to us MJ Fews in Charfield (as usual) or try Steve Hill in Bristol (have read some good reviews).
RAC man was recommending Finlandya Custom in Glastonbury (one of their approved repairers) as being good with Land Rovers, but I've never heard of them & can't find any reviews.
Has anybody on here used/heard of them?
Cheers,
Andy '57 Defender 110 XS Station Wagon 2.4tdci
Post #518406 28th Mar 2016 12:07pm
rustyboxx
United Kingdom 2015 Defender 90 Puma 2.2 CSW Montalcino Red
Loose injector? Had that on my 07 Puma once. 2015 90 XS CSW TDCi - Beautiful
2007 110 XS DCPU - An itch that needed scratching
2005 90 Td5 XS CSW - Utterly brilliant
2001 Discovery 2 ES Auto - A phase I went through
1996 90 Tdi CSW - Uber reliable
1989 90 2.5 Petrol Hardtop - My first proper Landy
1985 Range Rover Vogue V8 -Troublesome
Post #518474 28th Mar 2016 5:17pm
pumaxs
Hi rustyboxx,
Thanks for throwing that lifeline!
I'd consider myself to have got off pretty lightly if it was that quick & easy a fix.
I need a big garage bill like another hole in the head at the moment, especially so soon after having the clutch replaced.
Fingers crossed! '57 Defender 110 XS Station Wagon 2.4tdci
Post #518485 28th Mar 2016 6:02pm
dannyc85
United Kingdom 2007 Defender 90 Puma 2.4 CSW Stornoway Grey
Exact same problem mate the bolt holding the front 2 injectors had come loose. 2 minute fix.
Post #518712 29th Mar 2016 7:36am
SimonDavies
Wales 2010 Defender 90 Puma 2.4 HT Zambezi Silver
If the problem is that the injector has come loose, the bolt should really be replaced as I believe they are stretch bolts.
Personally I would renew the bolt which will hold two of the injectors and leave the top cover off, monitoring for any leaks (may have damaged the sealing washer). If all good after a week or so, refit the cover.
Post #518718 29th Mar 2016 8:00am
pumaxs
Morning Gents,
Have just removed plastic engine cover and could immediately see that the front two injectors were wet around their seatings.
Briefly fired up the engine & the fork clamping these injectors is rattling like a mini rocker shaft.
Will order new stretch bolts + sealing washers & get sorted by local garage.
I anticipate having a better nights sleep tonight!!!
Thanks again guys. Bow down '57 Defender 110 XS Station Wagon 2.4tdci
Post #518748 29th Mar 2016 10:00am
briggsy
I have just had all 4 injector's refurb'd and completed the change myself - I replaced these bolts for new ones, land rover state that they need to be tightened to 4nm and then turn a further 180 degrees which doesn't feel tight enough at all Shocked so I gave them what I thought felt right so I'm going to monitor closely.......even once you get a garage to replace them I would recommend also keeping a close eye for a few weeks.
Post #518759 29th Mar 2016 10:30am
Caterham
hi pumaxs,
just wondering how many miles has the engine done?
glad you've found the problem.
Post #518763 29th Mar 2016 10:39am
pumaxs
Just over 83k miles. '57 Defender 110 XS Station Wagon 2.4tdci
Post #518782 29th Mar 2016 11:12am
nickhodgson
Hi Puma XS
Has the engine ever had any other work done. It would be strange to my mind for injectors to become loose after 83k miles? Surely something has changed or was not fitted correctly. Did they do any other work when doing the clutch - can you not ask for a dealer print out to see if any warrantee work was done?
Nick 1995 300tdi Defender 90 P/UP
2011 Puma Defender 130 D/C
2000 300tdi Defender 110 P/UP
2015 Discovery 4 SDV6 HSE
Post #518825 29th Mar 2016 1:37pm
pumaxs
Hi Nick,
There's not been any obvious work carried out during my 4 years/35k miles of ownership that would have caused the injectors to loosen up.
Interestingly, the chap on Few's service desk said that they went through a phase of this problem being quite a common occurrence, but not so much of late.
He wondered whether the stretch bolts relaxed after while.
I said that was something a Defender owner could never do!! Laughing
Anyway, hopefully all will be sorted tomorrow.
Cheers,
Post #519003 29th Mar 2016 8:23pm
rustyboxx
Hey Andy, good to see it wasn't a major problem in the end 👍 2015 90 XS CSW TDCi - Beautiful
Post #519064 29th Mar 2016 9:53pm
pumaxs
Picked up my Defender from MJ Fews this afternoon.
They'd replaced sealing washers + clamping bolts for all injectors to be on safe side.
Total bill was circa �185, of which approximately �75 was for the parts.
All is good again. '57 Defender 110 XS Station Wagon 2.4tdci
Post #519406 30th Mar 2016 10:27pm
