- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
Riccarton
Modulars - how are they distinguished! | |
Having seen an ad' or two for Modulars recently I'm confused and need some educating from the assembled collective.
What is a "modular"?
I thought it was a steel wheel with an interchangeable centre so offset / PCD could be changed. However, I have seen ones advertised that are a welded construction so no alterations possible.
I presume I'm just not very bright
27th Mar 2016 8:22pm |
mikeh501
Not sure where the name comes from, but modulars as you've found out are cheap steel wheels which come in various styles (mostly relating to the holes), sizes (15/16" and 7"-10" width) and offsets (-35>+ . I'd assume most if not all come from China etc. I've got a set on my defender and they've done a great job standing up to some abuse 😀
27th Mar 2016 10:01pm |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
