Home > Maintenance & Modifications > Replacing front and rear plastic LR badge |
dunc Member Since: 31 Dec 2015 Location: surrey Posts: 132 |
I'm looking to replace both badges with the larger aluminium variety:
http://www.ebay.co.uk/itm/281938618402?_tr...EBIDX%3AIT On the front, what do the the rivets go through/hold on to? On the rear, is it OK to drill rivet holes in the approximate area of the current badge (no wires etc to be aware of?). I would prefer rivets instead of glue - is there any other recommended way to attach these? |
18th Mar 2016 6:41am |
discomog Member Since: 09 May 2015 Location: Notts/Lincs Border Posts: 2530 |
I've replaced both front grille and rear badges with aluminium old style badges. Very easy and straight forward. If you are concerned about wires at the rear the easiest way is to remove the rear speaker (held in with four screws). I used stainless steel pop rivets for the rear badge. For attachment to the front grille I used stainless machine screws and self locking stainless nuts with two black, powder coated pieces of flat bar behind the plastic grille.
Click image to enlarge Click image to enlarge Defender 90XS SW Mini Countryman Cooper S Morgan Plus 8 |
18th Mar 2016 8:31am |
CY88 Member Since: 05 Jan 2016 Location: Offshore Posts: 255 |
Gavin at Artmin Designs will make up some lovely smaller custom metal badges. For the front grille, I epoxied mine to a modified standard plinth....
18th Mar 2016 9:07am |
Two excellent (and different) suggestions - thank you!
CY88 - how much did you pay for the Artmin version? It looks a better quality product than OEM - sharper lettering and better paint |
18th Mar 2016 9:25am |
Artmin did the special edition badges for Landrover Ray
18th Mar 2016 9:37am |
Gavin at Artmin is an excellent chap and will make up badges to your own specification. I purchased my front and rears from him - excellent finish, well priced and have recommended him a number of times and everyone has been super impressed with the quality. Defender 90XS SW
18th Mar 2016 10:57am |
Cheaper for my two than the single badge in your ebay link, I seem to recall. And excellent quality. As stated, drop Gavin an email and he will quote for you to your specific requirement. Very helpful chap. Same badge on rear: Click image to enlarge |
18th Mar 2016 1:49pm |
Well it certainly sounds like Gavin from Artmin is the man!
A Google of Artmin produces a blog site, without a phone number - please could someone let me have Gavin's contact details. Thanks |
18th Mar 2016 2:11pm |
I'll pm you with his email address. Defender 90XS SW
18th Mar 2016 2:33pm |
Cheshire110 Member Since: 26 Jul 2013 Location: Cheshire/London Posts: 2760 |
its very easy to cannibalise a standard front badge to fit an old style one.
Will pop a couple of rivets in just to fill the holes and finish it off. Sits very flush to the grille which I'm happy about Click image to enlarge Click image to enlarge Click image to enlarge Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
18th Mar 2016 8:48pm |
EWS Member Since: 29 Nov 2011 Location: Bristol Posts: 156 |
Click image to enlarge My old Series 1 badge fitted to a KBX grill. ( camera fault showing ghost circle) |
19th Mar 2016 6:38pm |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2108 |
Now that DOES look good The colour theme of my truck is very much black/silver and I do believe you've tempted me to look at changing the badges now! If you don't mind me asking, what type is your steering guard? Is it aluminium or steel? |
19th Mar 2016 7:37pm |
nitram17 Member Since: 08 Jun 2014 Location: newcastle Posts: 2261 |
Any chance you could pm me the details also thanks in advance! |
19th Mar 2016 7:44pm |
Screbble, steering guard is from Flatdog. It is 8mm aluminium with mild steel brackets, zinc plated and powder coated. Only disadvantage is that you cannot fit jate rings. To overcome this I have fitted Nakatanenga recovery eyes to front bumper (from Brendan at 4x4 Overlander). Thoroughly recommend it and excellent value for money. Defender 90XS SW
20th Mar 2016 8:39am |
