Home > Maintenance & Modifications > Replacing front and rear plastic LR badge
Page 2 of 2 <12
discomog
Nitram 17.
pm sent Defender 90XS SW
Mini Countryman Cooper S
Morgan Plus 8
Post #516135 20th Mar 2016 9:42am
dunc
United Kingdom 2016 Defender 90 Puma 2.2 XS CSW Corris Grey
[quote="davidwhittaker"]its very easy to cannibalise a standard front badge to fit an old style one.
David
What adhesive would you recommend to stick the old badge to the new? Araldite type 2 pack, Gripfill, etc?
Post #516674 22nd Mar 2016 7:30am
Cheshire110
I literally just used superglue from Tesco, It was advertised as flexible though which seems good as didn't want it to go brittle and break off. Cheers, David
Post #516682 22nd Mar 2016 8:34am
CY88
1986 Defender 90 V8 Petrol ST Keswick Green
The plinth I had did not have a flat surface once I'd pulled the old badge off - it was curved like the old badge itself. I therefore had to sand flat the plastic first, which had the benefit of roughing it up a bit before sticking the metal badge on. Can't remember exactly what glue I used, but it was one of those epoxies that you have to mix the two parts together. I wanted to make sure it didn't fall off!
Post #516719 22nd Mar 2016 11:07am
Page 2 of 2 <12
