Home > Puma (Tdci) > I'm stumped!!
RED-DOT
I'm stumped!!
2008 Puma electrical problems.....
My rear wiper has packed in
Rear 2 low level brake lights come on when rear wiper switched on but no power to high level brake light
Engine wont turn off when rear screen heater is switched on
It is OK when rear heated screen is off
Earth at transfer is OK[/i] 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #501636 7th Feb 2016 12:17pm
mk1collector
Water mud or corroded rear tow socket can throw up funny problems. To rule it out quickly unplug the whole socket under the drivers side rear arch and try rear wiper etc. Ray
My build thread
Post #501665 7th Feb 2016 1:13pm
RED-DOT
I fitted a new Hella socket just prior to this lot coming to light! Is there another? 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #501680 7th Feb 2016 1:42pm
mk1collector
The tow socket wiring leads to a grey plug just behind the rear panel in the drivers side rear wheel arch. If you unplug this it should either fix the problem or rule the tow socket wiring out. Ray
My build thread
Post #501683 7th Feb 2016 1:50pm
RED-DOT
Thankyou, i will do that once the monsoon subsides! 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #501690 7th Feb 2016 2:05pm
mk1collector
Any luck? Ray
My build thread
Post #502440 8th Feb 2016 10:45pm
RED-DOT
Hi mk1, i was out foxing all night last night and that area is well caked in mud. I will hose it off tomorrow and see if i can find the plug. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #502448 8th Feb 2016 10:50pm
mk1collector
There's usually a plastic sheet up near the rear panel above the rear crossmember and it should be under that. Ray
My build thread
Post #502457 8th Feb 2016 11:07pm
RED-DOT
Ahh yes, i know where it is now. Mud city at the moment. So many niggles at the rear end! 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #502459 8th Feb 2016 11:12pm
RED-DOT
EUREKA!!! I found three broken black earth wires and one green/yellow wire inside the rubber accordion hose between the rear door and O/S quarter panel. Hides many gremlins and wires were soldered then crimped for a very happy outcome. Thanks Mk1 but the tow plug was OK but a little exposed for a major component .
RESULT! 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #515456 17th Mar 2016 7:34pm
mk1collector
Thumbs Up well done it's always a relief to find an annoying problem Ray
My build thread
Post #515477 17th Mar 2016 8:05pm
RED-DOT
I nearly gave up on this one but by luck i pulled at the wires and four came out the rubber conduit. I now have.....
Rear wipe
Rear wash
Rear de-mist
No stick on brake lights
3rd high level brake light
Engine turns off when rear de-mist is on
Repacked rear wiper motor with grease
Cheers!! 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #515482 17th Mar 2016 8:14pm
RED-DOT
This socket just hangs in mid air behind the fuel tank filler hose directly behind the O/S/R wheel where it must get blasted with 83mph grit and stones which although fine inside is surely asking for trouble? 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #515954 19th Mar 2016 11:47am
mk1collector
There should be a plastic shield that covers it and basically runs from the underside of the wheel tub to the top of the rear crossmember Ray
My build thread
Post #516052 19th Mar 2016 8:13pm
