![]() | Home > Puma (Tdci) > I'm stumped!! |
Water mud or corroded rear tow socket can throw up funny problems. To rule it out quickly unplug the whole socket under the drivers side rear arch and try rear wiper etc. Ray
RED-DOT Member Since: 29 Jun 2009 Location: stirling Posts: 2363 ![]() ![]() |
I fitted a new Hella socket just prior to this lot coming to light! Is there another? 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
The tow socket wiring leads to a grey plug just behind the rear panel in the drivers side rear wheel arch. If you unplug this it should either fix the problem or rule the tow socket wiring out. Ray
Thankyou, i will do that once the monsoon subsides! 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Any luck? Ray
Hi mk1, i was out foxing all night last night and that area is well caked in mud. I will hose it off tomorrow and see if i can find the plug. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
There's usually a plastic sheet up near the rear panel above the rear crossmember and it should be under that. Ray
Ahh yes, i know where it is now. Mud city at the moment. So many niggles at the rear end! 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
EUREKA!!! I found three broken black earth wires and one green/yellow wire inside the rubber accordion hose between the rear door and O/S quarter panel. Hides many gremlins and wires were soldered then crimped for a very happy outcome. Thanks Mk1 but the tow plug was OK but a little exposed for a major component .
RESULT! 2008 RS4 gone, 123d M Sport, and a Puma 90 XS.. |
![]() My build thread http://www.defender2.net/forum/topic17615.html |
I nearly gave up on this one but by luck i pulled at the wires and four came out the rubber conduit. I now have.....
Rear wipe Rear wash Rear de-mist No stick on brake lights 3rd high level brake light Engine turns off when rear de-mist is on Repacked rear wiper motor with grease Cheers!! 2008 RS4 gone, 123d M Sport, and a Puma 90 XS.. |
This socket just hangs in mid air behind the fuel tank filler hose directly behind the O/S/R wheel where it must get blasted with 83mph grit and stones which although fine inside is surely asking for trouble? 2008 RS4 gone, 123d M Sport, and a Puma 90 XS.. |
There should be a plastic shield that covers it and basically runs from the underside of the wheel tub to the top of the rear crossmember Ray
