![]() | Home > My Defender > Paint removal |
A good quality paint stripper works wonders then sand of what remains. Ray
db950 Member Since: 01 Feb 2012 Location: Lincoln Posts: 564 ![]() ![]() ![]() |
Don't have the aluminium panels blasted, it will stretch and warp them.
As already said, paint stripper would be the best option. |
gilly1969 Member Since: 16 Mar 2016 Location: Godstone Posts: 48 ![]() ![]() |
Thanks for the heads up. The guy I spoke to seemed to know his stuff giving me the impression he'd 'media cleaned' several Land Rovers in the past. He even explained how to take it apart. Maybe you're both right though. As I'm replacing all of the doors and the bonnet anyway, I could just invest in an orbital sander and some elbow grease to save myself a few bob. Out of interest, what's the most effective paint stripper?
gumdrop Member Since: 16 Jan 2010 Location: North Yorkshire Posts: 126 ![]() ![]() |
Soda blasting - not as aggressive as grit see Frosts website or Google Millar Soda Blasting. Cheers
Simon ------------------------- 50th D90 - my toy! Freelander SE Td4 3 door - local run around 1958 Series 1- Rag top! |
Here is a quote from another thread of some stuff recommended.I've never used it, I just sanded mine but wish I'd heard of it before!!
Thanks for the advice. Putting my environmentally responsible hat on, soda blasting sounds like a good option. I don't have a yard or workshop to work in so the problem I have with a chemical removal process is that I'll be swilling rubber eating paint stripper straight down the drain! I'll keep you all posted.
Talk to Michael Miller http://www.millarsodablasting.com/ - I bought my blaster off him. I got the dual version grit and soda - so far so good blasted ali and also a timber dresser - no steel as yet - you have to play around with pressure but once you get it correct works really well. He also does contract work his place hd a Jensen, Porsch and Beetle body shell in it. For all concerned I have no connection with him - just a really helpful guy
![]() Simon ------------------------- 50th D90 - my toy! Freelander SE Td4 3 door - local run around 1958 Series 1- Rag top! |
Thanks Simon. Now weighing up cost of buying/hiring equipment to do a DIY job versus sending it away to be done.
CY88 Member Since: 05 Jan 2016 Location: Offshore Posts: 255 ![]() ![]() |
Having done this recently on a car with 3 to 4 layers of brush applied paint, the soda blasting that the paint shop first attempted was not as efficient as the stripping solution that they resorted to. Depends on the type of paint that you're trying to remove though.
