Home > My Defender > What Did You Do In Your Defender Today |
Zinke Member Since: 27 Jan 2009 Location: Scunthorpe Posts: 670 |
Fitted a set of Terrafirma shockers today!
5th Jan 2011 6:07pm |
BigRuss Member Since: 15 May 2010 Location: Norfolk Posts: 2785 |
Which ones did you go for?? Russell 2011MY 110 XS USW Black |
5th Jan 2011 6:12pm |
Standard all terrain ones, think TS116 and TS117.
5th Jan 2011 6:18pm |
DefenderOfTheEarth Member Since: 09 Nov 2010 Location: Cornwall, UK Posts: 1304 |
Admired it but took the BM instead. BRRRRUMM BRRRRUMMM! Defender 110XS SW gone... now VW California 180 4 Motion.
5th Jan 2011 7:30pm |
BruceT Member Since: 01 Nov 2010 Location: South Africa Posts: 518 |
Travelled the cut lines through Botswana....hope I do this right....
http://www.flickr.com/photos/9885024@N05/5329119875/ (Thanks Glyn - dont know what happened to your post though.) |
6th Jan 2011 8:10am |
nikk Member Since: 27 Sep 2010 Location: Sliema Posts: 12 |
Beach combing on new years eve .
Click image to enlarge Click image to enlarge Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
6th Jan 2011 9:17am |
alanhid Member Since: 24 Jan 2010 Location: South Lanarkshire Scotland Posts: 221 |
Great pics Bruce................Im only a little bit jealous (he says as he looks out the window watching the sleety rain fall!) Same for you Nikk...........looks just like the beach at Ayr!! Life is not a rehearsal! Def 90td5 CSW xs 2006 |
6th Jan 2011 10:51am |
TC Member Since: 21 Nov 2010 Location: Gloucestershire Posts: 715 |
Awesome :thumbsup: Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
6th Jan 2011 12:25pm |
party monkey Member Since: 31 Dec 2010 Location: Oxon. Posts: 1311 |
Had BGF AT's fitted to replace the worn out Grabber TR's - bring on some more snow ! Jon - 110 td5 [sold]. Currently Defenderless.
6th Jan 2011 1:55pm |
smorland Member Since: 04 Oct 2010 Location: uk Posts: 13 |
new fuel filter, fixed a short in the left hand indicators and replaced the cracked surround on the hazard/fog light switch
6th Jan 2011 11:13pm |
T1G UP Member Since: 08 Dec 2009 Location: Bath Posts: 3101 |
dropped my non charging td5 90 to the auto electricians
2 hours later and £20 lighters shes charging done a good few miles around Bristol today...up the m5 aswell, got to change the transferbox now as a 1.4 is to low for me. |
6th Jan 2011 11:16pm |
Just a quick pic or the rear shocks. On the left is the Terrafirma All Terrain and the right is the standard land rover shock. They both close up to about the same length within a few mm but as you can see they have much more travel. Click image to enlarge The fronts are about the same too, which is causing a little problem with keeping the springs in the seats but looking at solutions! Pete. |
7th Jan 2011 12:15pm |
alantd Member Since: 14 Dec 2008 Location: Northamptonshire Posts: 1513 |
Zinke: wouldn't dislocation cones be your solution?
BruceT: just flicking through some of your historical photos - fantastic. Those shots of the lightning are outstanding. Did you take them? One that started out as a 2.4 TDCi 110 XS + New Defender 110 First Edition |
7th Jan 2011 1:13pm |
Think if i just got some spring retainers for the front it will work ok, the front strings arent fixed onto the mount on the axle like the rears are so hopefully this will help and then will get some dislocation cones if there still needed.
Pete. |
7th Jan 2011 1:24pm |
