Home > Puma (Tdci) > Puma 110 MY11 - Leaking
Page 1 of 3 123>
BruceT
South Africa
Hi All,
I recently purchased this Puma after a long relationship with a TD5. So far very happy, except I see they have moved the right water leak from the front drivers foot well to the right back behind the speaker panel. I have taken the speaker out and it appears the water is comming in from the right window side but cannot see and am not sure how to remove the plastic panel to see behind.
Any ideas or pointers please?
Thank you.
Post #51302 6th Jan 2011 8:33am
willy eckerslike
United Kingdom 2007 Defender 110 Puma 2.4 HCPU Keswick Green
If you look on the outside corner you'll probably see the seal has been pulled to far inside, get the dealer to sort it. Thumbs Up Original Member Pie n Pea Club.
110 HCPU Tipper
Post #51307 6th Jan 2011 9:03am
BruceT
South Africa
Thanks Willie. Have checked that already and the seal is in place.
Post #51308 6th Jan 2011 9:05am
willy eckerslike
Ok bruce, my windows also leak could be running round. I'm going to remove the rear carpet and run around for a while till i've seen all the leaks and then seal them myself with silastic. Rear seat mounts also leaked on mine. Put it this way it would never float. latest one is when driving fast up the wet motorway with the drivers side window partially down, it sucks water in through the door seal and you get a wet kidney. you've got to love em Thumbs Up Original Member Pie n Pea Club.
110 HCPU Tipper
Post #51311 6th Jan 2011 9:10am
BruceT
South Africa
Thanks again Willy.
I think I will do the same.
How are the plastic panels around the windows removed?
Post #51313 6th Jan 2011 9:24am
willy eckerslike
Above are partially held on by the hand holds then clips, the lower is on clips. Original Member Pie n Pea Club.
110 HCPU Tipper
Post #51324 6th Jan 2011 10:05am
BruceT
South Africa
ok thanks again. Will try not to break any when I remove the panel.
Post #51326 6th Jan 2011 10:31am
ralton
South Africa 2007 Defender 90 Puma 2.4 SW Zermatt Silver
Umm, this isn't the only leak you have. It's just the only one you've noticed so far.
Land Rover have a special "Water Ingress Manual" which describes fixes for the many leaks you haven't seen!
PM me anybody that would like a copy of this PDF document.
Cheers www.ralton.co.za
Post #52337 11th Jan 2011 11:21am
BruceT
South Africa
Ralton......have you got the latest one or the one thats been floating around since before the Puma?
Thank you
Post #52339 11th Jan 2011 11:24am
szracer
England 2010 Defender 110 Puma 2.4 USW Stornoway Grey
Can heartily recommend Captain Tolley's Creeping Crack cure!
No connection with them, but I've used it for ages on various old cars, and being very viscous and thin, it seems to get in an seal where dumdum or silicone can't!
2010 110 XS USW (the slow one)
1960 Alfa Romeo Giulietta SZ (the fast one)
2005 Ducati ST3
1954 Sunbeam S8
Post #52340 11th Jan 2011 11:27am
ralton
Thank you
I have no idea - it does look a bit aged...
EDIT - it's a 2005 document.. www.ralton.co.za
Post #52348 11th Jan 2011 11:33am
mse
Sometimes water makes it in around the filler...have a look you will see the holes!! Mike
Post #52368 11th Jan 2011 1:15pm
BruceT
South Africa
Thanks Mike. I blocked those already.
Post #52370 11th Jan 2011 1:17pm
mse
You checked the loom plugs are seated properly i assume (although it would be water spraying differently) Mike
Post #52375 11th Jan 2011 1:27pm
BruceT
South Africa
What are the loom plugs?
Post #52376 11th Jan 2011 1:30pm
Page 1 of 3 123>
