Home > Maintenance & Modifications > Rear Wiper
Stiff1
Rear Wiper
Just a quick check, do you have to remove the spare wheel in order to change the rear wiper... or am I missing something obvious?
Post #513034 10th Mar 2016 10:34pm
DAZ110
United Kingdom 2013 Defender 90 Puma 2.2 XS CSW Barolo Black
Yes
Post #513036 10th Mar 2016 10:38pm
driver9
Managed to change the wiper blade on my Puma without removing the wheel.
Post #513037 10th Mar 2016 10:40pm
Screbble
You should be able to change the blade without removing the wheel, but to do the arm it's a wheel off job Thumbs Up
Post #513043 10th Mar 2016 10:53pm
Birdy
France 2011 Defender 110 Puma 2.4 XS CSW Santorini Black
I've never been able to do it without removing the wheel, even if you switch the ignition off when the arm is in the vertical position.
Peter
Post #513047 10th Mar 2016 11:09pm
Stiff1
That is what I am finding.
Post #513050 10th Mar 2016 11:16pm
RRUK
I swapped mine to a Bosch Aerotwin flat blade, but had to remove the rear wheel to get at it properly. 2016 D4 HSE
1982 Series 3 SWB Petrol
Post #513103 11th Mar 2016 8:35am
ericvv
Post #513108 11th Mar 2016 8:57am
