Home > Spotted > Strange Wolf
Page 2 of 2 <12
Grenadier
Must say, I do like the look of he side wheel carrier. Have been thinking about it as a mod on any future DC if I get a full external roll cage. Thoughts? Thumbs Up Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #511665 7th Mar 2016 4:06pm
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
The Wolf side carrier is able to swap to either side depending on where you are, also the side with the wheel has an extended mirror arm. It does increase the blindspot and also when driving narrow roads you need to think of the overhang, living in Guernsey I take the spare off as the roads/lanes can be tight. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #511666 7th Mar 2016 4:32pm
Grenadier
Cheers Mash. Let's be honest though, we Defender drivers accept many difficulties, hurdles, faults, incoveniences etc, as long as we like the look!! Otherwise most of use would t buy a Defender in the first place!! Whistle Monsieur Le Grenadier
Post #511670 7th Mar 2016 4:38pm
Mash
That is very true, you do get used to it after a while. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
D3 Hse - Fiona
Capri 2l S - Anna
Post #511674 7th Mar 2016 4:52pm
theorangebandit
Shamefully I worked on this project, the level of workboutput is shocking, those hole covers disgusted me. Hated building them to the insisted spec. One of those 90s roll cages split my cheek open, a lasting memory of the project lol they're riddled with bodged closed holes on the body panels the rear tailgate is modified to swing open and not fold down, avoiding the slamming against the nato hitch when lazy people couldn't be bothered to secured the retainer straps.
Post #511722 7th Mar 2016 6:52pm
Mash
So what is the reason to the moving of the lights? Does the wheel carrier fowl them? 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
D3 Hse - Fiona
Capri 2l S - Anna
Post #511728 7th Mar 2016 6:58pm
theorangebandit
Browny90 wrote:
Mash wrote:
That rear crossmember plate is looking a little dodgy.
You would thing they would have touched that up when fitting the carrier..
They were all repaired /overhauled before the REMUS fit, they all got a respray and full chassis protection. But despite the arguments us contractors put forward, coat had a profound over ruling. Many of the chassis work required was simply sprayed over. Very typical idle ABRO build quality.
These motors were left sitting for almost 2 years before they all got collected(not sure what went wrong in the comma for that to happen) lots were returned for more works and refused receipting for shody tyres (a huge argument between an inspectors opinion and genuine MEI standards) we tried to put out good work honestly we really did, but we were swimming in some one elses pool
Post #511735 7th Mar 2016 7:06pm
theorangebandit
It was due to the tail light being modified into a stop/tail, the other light became redundant We attempted to argue simply fitting extra lighting in the holes but got shot down
Post #511737 7th Mar 2016 7:07pm
If it was for this then the grommet would have gone into the now redundant brake lamp fitting - lower right.
Instead, the fitting of the wheelcarrier necessitated the indicator light being moved to the outer position to ensure that hazard lamps would be visible from the rear with the swingaway carrier open.
Basically to ensure compliance with UK law.
Post #511962 8th Mar 2016 11:13am
Mash
Thumbs Up cheers for the input, had wanted to mug off the lighting side of this mod if I ever got it for mine, now I know the reasons as long as I keep the door/swing away shut I can get away with it. Either that or a new rear panel will be sourced because those rubber bungs look Censored 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
D3 Hse - Fiona
Capri 2l S - Anna
Post #511970 8th Mar 2016 11:33am
I haven't checked but is there a reason the brake light and the indicator could not have just been swapped with each other?
Post #512017 8th Mar 2016 1:30pm
Page 2 of 2 <12
