Home > Puma (Tdci) > Puma Rear diff noises |
Marius Member Since: 21 Dec 2010 Location: South Africa Posts: 231 |
Had a drive in a 90 yesterday.....NO noises. Also noted that perhaps these are due to clucth issues and not diff issues. When you drive and engage/disengage clucth without changing gears there is no noises due to roughly the same revs on prop side/gearbox side. THis to me suggest either clucth or syncro on gearbox issues. the diff noises are poccibly only a symtom due to the faulty clutch. Going in on thursday for a look.
4th Jan 2011 12:18pm |
carlaac Member Since: 09 Dec 2010 Location: Hampshire Posts: 58 |
Marius
This might be obvious but have you shifted the transfer box whilst moving? If so run in low come to standstill clutch, neutral, clutch, high, roll on gently might reset the transfer gearbox wind-up. I had a heavy knocking after a spin in low-range this sorted it and transmission and diffs now silent again. Good luck, all this talk of replacement diffs is scaring me, only done 3k in mine and when it started knocking I though "here we go.." Above sorted it though |
4th Jan 2011 10:20pm |
I'm not understanding you entirely. So I run run in low range and come to a standstill in gear with clucth depressed. Now I change to neutral and then change to high range and start going off gently? |
5th Jan 2011 6:53am |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2635 |
I do that at least once a week just to work the box & linkages, no effect on the drivetrain backlash. |
5th Jan 2011 7:14am |
That's funny. I went to N1 City on Tuesday and had the senior technical guy drive my landy. His first comment was 'this is one of the smoothest Pumas I have driven' - which totally bowled me over. I then drove a brand new 90, and guess what? It made the same noises that mine did - gearbox clunking going in & out of 3rd, drivetrain backlash, etc. So I guess this is a standard feature on mine and must just learn to shift more smoothly. |
5th Jan 2011 7:21am |
NO WAY Naks. I drove a friends 90 Puma 2 days ago with absolutely NO noises. shifted like a toyota camry! |
5th Jan 2011 7:27am |
now what do I do? I'm in 2 minds about taking it to LR Stellenbosch, 'cos their foreman drove my landy and said he also feels there's too much clunking in the gearbox. But the last time I used them with my 110 Td5, they replaced a gearbox unnecessarily (when the problem was a propshaft) and forgot to put the gearbox cowling back, so not too happy about that. |
5th Jan 2011 7:31am |
Grockle Member Since: 24 Nov 2008 Location: Peak District National Park Posts: 2266 |
mates 2 month old 90 needs a new rear dif, guess what on back order 2.4 90 XS
5th Jan 2011 8:31am |
HORAAAAA!!!!! This actually in the end sorted out my problem!!!!!!!! Thanks!!!! |
6th Jan 2011 9:31am |
u suck! but only because this has not solved mine Going in for its first service in 2 weeks' time at LR Stellenbosch. At least the foreman there did concede the gearbox had an unusual clunk, so let's hope they sort it out. I'll try the low-high trick again tomorrow and see. |
6th Jan 2011 9:47am |
BruceT Member Since: 01 Nov 2010 Location: South Africa Posts: 517 |
I had the clunk and after spending the last 4 days and 500 odd kms off road, towing a heavy off road caravan in mostly HR3 and sometime LR1. I have noticed no more clunk since getting back onto the road and "normal" gears. Wondered what had happened.
6th Jan 2011 10:38am |
Odd... maybe I should skip work tomorrow and go to Atlantis Dunes |
6th Jan 2011 10:56am |
yes just do it Naks......
6th Jan 2011 11:08am |
Seems the clunk in allot of cases is transmition windup.....or possibly the inability to wind it down....
I still have the clunk if I shift like a lunitick. If I just take care to shift well the noise is 100% gone! I am so relieved. I was starting to develop trust issues with my new steed. |
7th Jan 2011 7:16am |
