Home > Puma (Tdci) > turning circle |
Yeah, just adjust the stops and all should be normal small oil tanker turning circle instead of big oil tanker Ray
1st Mar 2016 10:48am |
have look at the link http://defender90xs.blogspot.co.uk/2013/11...tment.html |
1st Mar 2016 11:13am |
X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2293 |
Thanks dorsetsmith
Top 'information resource'... http://defender90xs.blogspot.co.uk/2013/11...tment.html SKIP https://www.defender2.net/forum/topic83242.html |
1st Mar 2016 11:36am |
Doubledoom Member Since: 27 Dec 2015 Location: Suffolk Posts: 42 |
Should there be any difference between an 09 and 14 in respect of turning circle?
I didnt think they had got any worse but were equally as bad. |
1st Mar 2016 12:05pm |
discomog Member Since: 09 May 2015 Location: Notts/Lincs Border Posts: 2525 |
I love Ray's analogy of small oil tanker/big oil tanker. Defender 90XS SW
1st Mar 2016 12:06pm |
dudley472 Member Since: 15 Nov 2012 Location: wolverhampton Posts: 96 |
perfect thanks very much,
1st Mar 2016 1:06pm |
Roy5695 Member Since: 15 Feb 2014 Location: Cornwall Posts: 1123 |
I adjusted my stops yesterday and can confirm the above statement about oil tankers
3rd Mar 2016 6:08pm |
Thon Member Since: 22 Nov 2015 Location: Salisbury Plain Posts: 696 |
I used to be an avid trialer with my first 90 and had the lock stops adjusted so the tyre would touch the radius arm.
Every little helps when you're trying to squeeze between the gates |
3rd Mar 2016 6:35pm |
RRUK Site Supporter Member Since: 31 Mar 2010 Location: Leicestershire Posts: 2019 |
Question.
When adjusting, do you adjust with the wheels turned inwards or outwards or both? 2016 D4 HSE 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 SWB Petrol |
3rd Mar 2016 6:43pm |
Adjusting the n/s stop check on the rear of the o/s wheel and vice versa. Ray
3rd Mar 2016 6:50pm |
Wild Card 90 Member Since: 03 Dec 2014 Location: Gerlingen Posts: 1060 |
It depends on what wheels you had on the two vehicles, and whether they are both set up for maximum lock. Wider offset wheels allows you to dial in more steering lock, and thereby improve the turning circle. Spacers have the same effect. With the wide offset of the ZUīs and 30mm spacers, my 90 turns "on a dime". 1998 Tdi 90 SW, 2008 Td4 90 SW, 2012 2.2 90 SW, 2" raised Trailmaster/Terrafirma Heavy Track Raids, 255 MTīs, Recaro CSīs, anorak, wellingtons |
3rd Mar 2016 7:18pm |
