Home > Puma (Tdci) > what is this code???? |
bob neville Member Since: 30 Apr 2009 Location: Marbella Posts: 3248 |
Answer in this thread
http://www.defender2.net/forum/topic4311.html Bob |
3rd Jan 2011 3:46pm |
Alexke Member Since: 03 Jan 2011 Location: Antwerp Posts: 113 |
Fuel Rail Sensor In-Range High Failure:
# High Fuel Pressure. # Low fuel pressure. # Damaged FRP sensor. # Excessive resistance in the circuit. this is from google |
3rd Jan 2011 3:48pm |
yanto Member Since: 03 Sep 2009 Location: caerleon Posts: 230 |
Thanks for fast replys, its due to be picked up by landrover asst but if it is safe to drive there i would rather do that, do you think its ok to drive the 5 miles to dealer?
3rd Jan 2011 4:09pm |
no , I did that , and they said : if you waited , its landroverīs responsibility to give you a replacement car , if you bring it to the dealer , you dont get one...
atleast here in Belgium |
3rd Jan 2011 4:15pm |
I would let LR Asst. take it in if they are on their way.
Nothing worse than cancelling them and then breaking down on the way to the dealers. Bob |
3rd Jan 2011 4:16pm |
Good advice there guys thanks, hope i dont get a nasty rangerover sport for a courtesy car???
3rd Jan 2011 4:21pm |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 |
I had this exact fault a few months ago and the dealer replaced the fuel rail under warranty Annoying thing was they had to order the part in as it happened on a Sunday and the part didn't arrive till Tuesday. As the wife also has a car did not bother with the courtesy car, less hassle.
3rd Jan 2011 4:50pm |
