Home > Maintenance & Modifications > Coolant loss, could it be the cap? |
Dave-H Member Since: 08 Feb 2011 Location: Surrey Posts: 1507 |
Couldn't say for definite with that much loss, but mine and a relative's both used to drop a couple of inches over a few weeks ... New caps on both solved the problem
For a sake of a few quid it's worth a try. Guns and Landrovers .... anything else is irrelevant. |
13th Feb 2016 7:47am |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2645 |
Mine was also losing coolant until I replaced the cap.
I now replace it every year, it's cheap -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
13th Feb 2016 7:57am |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20440 |
Excellent guys, will try a new cap and got some new coolant on the way.
If it doesn't work, well, it was worth a go but it's possible. It's the same cap that I've had since I've had it in 2010 so possibly from new. Will see how it goes. Thank-you. |
13th Feb 2016 11:17am |
d.tribe Member Since: 11 Apr 2015 Location: hampshire Posts: 9 |
My 2.2 110 is doing the same thing.
Does anyone happen to know the part number for the cap? |
13th Feb 2016 7:48pm |
Not off the top of my head, I have enquired with Dan @ Duckworth parts.
I can let you know probably as of Monday if you like? |
13th Feb 2016 7:50pm |
gazman Member Since: 17 Aug 2015 Location: Liverpool Posts: 652 |
Mine was the cap. But it never went empty, just dropped about 2 to 3 cm and stayed there 2014 - current ..... 2003 defender td5 90 (my car)
2009 - current .... 2005 zx10r |
13th Feb 2016 8:00pm |
Yeah that would be great. Thanks.
I've had a look online and can only find td5 or tdi part numbers. Dave |
13th Feb 2016 8:01pm |
Will let you know after I hear back then.
13th Feb 2016 8:13pm |
For those interested the P/N is: PCD100160
15th Feb 2016 1:34pm |
DonH2000 Member Since: 12 Jan 2015 Location: North Kent Posts: 551 |
Mine did the same so I replaced the cap twice.... in the end I had to change the expansion tank and now a year later not had a repeat of the problem and all is OK. Cheers Don. |
15th Feb 2016 2:03pm |
Well, small update.
Changed the cap, still the level of fluid is dropping so further investigation is required today. |
25th Feb 2016 10:13am |
Mash Member Since: 09 Feb 2015 Location: Guernsey Posts: 1674 |
I have a coolent pressure test kit and hopefuly won't be working this weekend if you are close to Aldershot. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
25th Feb 2016 10:21am |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6300 |
I don't like over tightening things but from what I've seen this cap does need to be pretty tight.
hope you find the cause and it ain't too expensive / difficult to resolve. |
25th Feb 2016 10:28am |
Mash - Thank-you for the kind offer but I am a long way away sadly.
I'm going to have a proper poke around today as I've got a day off anyway do I'll see what I can find. Being orange OAT coolant it shouldn't be difficult to locate but I think it's out of sight hidden. Doesn't help having orangey driveway grit either. |
25th Feb 2016 10:37am |
