Home > Maintenance & Modifications > Coolant loss, could it be the cap?
As above, my 90's been losing coolant lately fairy slowly but recently much much more.
Now from header tank fluid level to the very bottom of the tank in 12 days flat.
My first thought is a leak, but would the cap / any pressure lost through it be possible?
Or is the amount too much for that to be the case?
The cap once removed seems to usually be wet inside it for some reason.
Thoughts?
Thumbs Up
Post #504101 12th Feb 2016 9:14pm
Dave-H
England 2007 Defender 90 Puma 2.4 HT Tonga Green
Couldn't say for definite with that much loss, but mine and a relative's both used to drop a couple of inches over a few weeks ... New caps on both solved the problem Thumbs Up
For a sake of a few quid it's worth a try. Guns and Landrovers .... anything else is irrelevant.
Post #504202 13th Feb 2016 7:47am
Naks
Mine was also losing coolant until I replaced the cap.
I now replace it every year, it's cheap Thumbs Up --
Post #504203 13th Feb 2016 7:57am
Excellent guys, will try a new cap and got some new coolant on the way.
If it doesn't work, well, it was worth a go but it's possible.
It's the same cap that I've had since I've had it in 2010 so possibly from new.
Will see how it goes. Thumbs Up
Thank-you.
Post #504253 13th Feb 2016 11:17am
d.tribe
My 2.2 110 is doing the same thing.
Does anyone happen to know the part number for the cap?
Post #504365 13th Feb 2016 7:48pm
Not off the top of my head, I have enquired with Dan @ Duckworth parts.
I can let you know probably as of Monday if you like?
Post #504369 13th Feb 2016 7:50pm
gazman
United Kingdom 2003 Defender 90 Td5 HT Alpine White
Mine was the cap. But it never went empty, just dropped about 2 to 3 cm and stayed there 2014 - current ..... 2003 defender td5 90 (my car)
2009 - current .... 2005 zx10r
Post #504379 13th Feb 2016 8:00pm
d.tribe
Yeah that would be great. Thanks.
I've had a look online and can only find td5 or tdi part numbers.
Dave
Post #504380 13th Feb 2016 8:01pm
Will let you know after I hear back then. Thumbs Up
Post #504386 13th Feb 2016 8:13pm
For those interested the P/N is: PCD100160
Post #504876 15th Feb 2016 1:34pm
DonH2000
United Kingdom 2009 Defender 90 Puma 2.4 XS CSW Santorini Black
gazman wrote:
Mine was the cap......... just dropped about 2 to 3 cm and stayed there
Mine did the same so I replaced the cap twice.... in the end I had to change the expansion tank and now a year later not had a repeat of the problem and all is OK. Cheers Don.
Post #504882 15th Feb 2016 2:03pm
Well, small update.
Changed the cap, still the level of fluid is dropping so further investigation is required today.
Post #507933 25th Feb 2016 10:13am
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
I have a coolent pressure test kit and hopefuly won't be working this weekend if you are close to Aldershot. Thumbs Up 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #507935 25th Feb 2016 10:21am
Caterham
I don't like over tightening things but from what I've seen this cap does need to be pretty tight.
hope you find the cause and it ain't too expensive / difficult to resolve.
Post #507938 25th Feb 2016 10:28am
Mash - Thank-you for the kind offer but I am a long way away sadly.
I'm going to have a proper poke around today as I've got a day off anyway do I'll see what I can find.
Being orange OAT coolant it shouldn't be difficult to locate but I think it's out of sight hidden.
Doesn't help having orangey driveway grit either. Laughing
Post #507942 25th Feb 2016 10:37am
