Home > Maintenance & Modifications > Rust on engine block |
RLD Member Since: 29 Jun 2007 Location: Lancs Posts: 858 |
well all metal of any sort will get rust or corrode it at some time as engine block are made of metal has it had ant water snow or got damp at all as this will put rust on it RLD fabricator of Hidden Winch Mount for D3/4 roof racks jerry can holders CB aerial mounts and much more and agent for Helsport Tents and gear
30th Dec 2010 2:01pm |
Denis Member Since: 28 Dec 2010 Location: prairie Posts: 58 |
So thats ok? I'm worry that it is new engine Puma 110
30th Dec 2010 2:05pm |
warren Member Since: 14 Oct 2009 Location: East Lancs. Posts: 903 |
Mine got like that after about 6 weeks, especially on the fuel rail. Must admit it does look nasty, especially if the rest of the engine bay is clean.
30th Dec 2010 2:11pm |
As mine just now! Puma 110 |
30th Dec 2010 2:15pm |
pom Member Since: 01 Jun 2010 Location: Worcester Posts: 1343 |
don't worry LR do not charge extra for it and the dealers help it along for free as well.
Pom |
30th Dec 2010 2:34pm |
I'd like to know what dealers in UK do to get rid of rust? Because my dealer said "it's ok" - I'm in Russia Puma 110
30th Dec 2010 2:42pm |
sasha2001 Member Since: 02 Jan 2009 Location: New Zealand+ russia Posts: 206 |
I am in New Zealand near the sea and have a little rust on the engine block, I just sprayed a product called Corrision x all over it and on nuts and bolts etc, my friend is a helicopter engineer and they use this stuff on airframes out in Malaysia all the time especially between aluminum and steel etc in the humid climates http://www.corrosionx.com/hd.html Not sure if its available in your neck of the woods!!! I visit most years to a place not so far from you Рязань where my wife's family lives. |
31st Dec 2010 8:38pm |
Thanks for your reply Sasha2001! Very much appreciate it! Will try it.
Happy New Year and best wishes to you and your wife! Happy New Year to all Defender-addicted! Puma 110 |
31st Dec 2010 9:46pm |
С Новым Годом!!! |
31st Dec 2010 11:29pm |
Mates,
engine block is made on CAST IRON..... so is similar to the stainless steel.... the block produce a cover on passive oxide not more!!!!! Not corrosion!!! Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
1st Jan 2011 3:57pm |
Thanks dgardel! I saw Def 2006MY with unreadable engine number due to that cover on the lower part of engine. Upper part of engine was clear. So I worried about that issue. So there is nothing to worry about? Puma 110 |
2nd Jan 2011 6:23pm |
Absolute do not worry!!!
all new engine (Range and Discovery too and not only Land rover) have no paint on the block. In the pas the block was colored in black or orange or ..... Now no paint => cost reduction!!!! Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
2nd Jan 2011 7:24pm |
Thanks for explanation! Puma 110 |
2nd Jan 2011 7:36pm |
