Home > Puma (Tdci) > Rusty water in passenger footwell |
Wild Card 90 Member Since: 03 Dec 2014 Location: Gerlingen Posts: 1060 |
There are two unpainted metal strips that run across the bulkhead above both footwells. Standard issue. If the seal between screen and bulkhead is faulty, the resulting water that runs down back of the bulkhead, behind the dash appears at the bottom as a rusty yellow soup.
Your (6 year) corrosion garantee runs out in 2018... Dealer - lift roof, remove dash, screen frame out...the full monty. 1998 Tdi 90 SW, 2008 Td4 90 SW, 2012 2.2 90 SW, 2" raised Trailmaster/Terrafirma Heavy Track Raids, 255 MTīs, Recaro CSīs, anorak, wellingtons Last edited by Wild Card 90 on 9th Feb 2016 11:24am. Edited 1 time in total |
9th Feb 2016 11:19am |
LandyBen82 Member Since: 22 Jul 2014 Location: Shropshire Posts: 44 |
Warranty is finished now...... Is there another option?
Thanks - Ben |
9th Feb 2016 11:21am |
The corrosion garantee is valid for 6 years, I believe. Maybe because it is a leak, it doesnīt qualify initially...but once the rusty soup has gathered, you should have something to go on. Good luck. 1998 Tdi 90 SW,
2008 Td4 90 SW, 2012 2.2 90 SW, 2" raised Trailmaster/Terrafirma Heavy Track Raids, 255 MTīs, Recaro CSīs, anorak, wellingtons |
9th Feb 2016 11:27am |
You are right. "Corrosion caused by another defect" is not covered. Damn! Have a look behind the dash, by taking out the footwell speaker. You will need to find someone who knows their way around the gasket between windscreen frame and bulkhead. 1998 Tdi 90 SW,
9th Feb 2016 12:02pm |
Happyoldgit Member Since: 14 Sep 2007 Location: Norfolk Posts: 3471 |
If the screen frame to bulkhead seal is suspect the easiest thing to do is run a bead of sealant along the join and around the corner by the door seals. make sure you do this with everything nice and dry, removing the wiper arms makes it easier to get a neater finish.
Also worthwhile checking that the drain points are clear of muck and debris. Steve. Owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. |
9th Feb 2016 1:18pm |
Gleaney Member Since: 03 Dec 2012 Location: Earth! Posts: 94 |
Get some Captain Trollys creeping crack cure. Run it along the seal on the bulkhead. Problem will go. I had same problem.
Get it off amazon. Damn planet is short of Kryptonite ! |
9th Feb 2016 2:21pm |
Penguin Member Since: 08 Dec 2014 Location: Tienen Posts: 247 |
16th Feb 2016 4:10pm |
16th Feb 2016 4:11pm |
16th Feb 2016 4:14pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20474 |
Heard about that many times before, what is it exactly? |
16th Feb 2016 5:20pm |
http://www.amazon.com/Captain-Tolleys-Cree...B00JQ6XHWC 28/02 - Loss of a good friend...
In a time of chimpanzees, I was a penguin. |
16th Feb 2016 5:41pm |
Thank-you.
16th Feb 2016 6:00pm |
Alphabear Member Since: 10 Oct 2015 Location: South Wales Posts: 51 |
My 90 had the exact leak running through the join in the dash at knee height. The metal strip which you can see at the end of the join is the rusting metal as it's completely untreated. After having the windscreen resealed and the bulkhead resealed, the leak was identified as being through the rubber grommet that would be the windscreen wiper hole on a left hand drive vehicle. Amazing how much water it was letting in and now completely dry.
16th Feb 2016 6:07pm |
JAY BOY Member Since: 04 May 2010 Location: Not here Posts: 1706 |
Mine was the same
They tried 3 times before they eventually sorted it. |
16th Feb 2016 7:48pm |
