Home > Puma (Tdci) > Rusty water in passenger footwell
LandyBen82
United Kingdom 2012 Defender 90 Puma 2.2 HT Firenze Red
Hi all!! Can you help me with this problem?? I hope the pic's explain all.
Many Thanks - Ben
Post #502573 9th Feb 2016 11:07am
Wild Card 90
England 2012 Defender 90 Puma 2.2 SW Indus Silver
There are two unpainted metal strips that run across the bulkhead above both footwells. Standard issue. If the seal between screen and bulkhead is faulty, the resulting water that runs down back of the bulkhead, behind the dash appears at the bottom as a rusty yellow soup. Shocked
Your (6 year) corrosion garantee runs out in 2018...
Dealer - lift roof, remove dash, screen frame out...the full monty. 1998 Tdi 90 SW,
2008 Td4 90 SW,
2012 2.2 90 SW,
2" raised Trailmaster/Terrafirma
Heavy Track Raids, 255 MTīs,
Recaro CSīs, anorak, wellingtons
Post #502578 9th Feb 2016 11:19am
LandyBen82
Warranty is finished now...... Is there another option?
Thanks - Ben
Post #502580 9th Feb 2016 11:21am
Wild Card 90
The corrosion garantee is valid for 6 years, I believe. Maybe because it is a leak, it doesnīt qualify initially...but once the rusty soup has gathered, you should have something to go on. Good luck. 1998 Tdi 90 SW,
2008 Td4 90 SW,
2012 2.2 90 SW,
Post #502584 9th Feb 2016 11:27am
Wild Card 90
You are right. "Corrosion caused by another defect" is not covered. Damn! Have a look behind the dash, by taking out the footwell speaker. You will need to find someone who knows their way around the gasket between windscreen frame and bulkhead. 1998 Tdi 90 SW,
2008 Td4 90 SW,
2012 2.2 90 SW,
Post #502595 9th Feb 2016 12:02pm
Happyoldgit
If the screen frame to bulkhead seal is suspect the easiest thing to do is run a bead of sealant along the join and around the corner by the door seals. make sure you do this with everything nice and dry, removing the wiper arms makes it easier to get a neater finish.
Also worthwhile checking that the drain points are clear of muck and debris. Steve.
http://forums.lr4x4.com
Post #502628 9th Feb 2016 1:18pm
Gleaney
United Kingdom 2010 Defender 90 Puma 2.4 XS CSW Stornoway Grey
Get some Captain Trollys creeping crack cure. Run it along the seal on the bulkhead. Problem will go. I had same problem.
Get it off amazon. Damn planet is short of Kryptonite !
Post #502653 9th Feb 2016 2:21pm
Penguin
Belgium 2015 Defender 110 Puma 2.2 HT Chawton White
We just noticed the same issue on our 2015 110 :S
Is it worth taking to the dealers, or would extra sealing on the bulkhead suffice? 28/02 - Loss of a good friend...
In a time of chimpanzees, I was a penguin.
Post #505204 16th Feb 2016 4:10pm
Penguin
Post #505206 16th Feb 2016 4:11pm
Penguin
We just noticed the same issue on our 2015 110 Sad
Post #505207 16th Feb 2016 4:14pm
Get it off amazon.
Heard about that many times before, what is it exactly?
Post #505223 16th Feb 2016 5:20pm
Penguin
http://www.amazon.com/Captain-Tolleys-Cree...B00JQ6XHWC 28/02 - Loss of a good friend...
Post #505231 16th Feb 2016 5:41pm
Thank-you. Thumbs Up
Post #505237 16th Feb 2016 6:00pm
Alphabear
Wales 2015 Defender 90 Puma 2.2 HT Scotia Grey
My 90 had the exact leak running through the join in the dash at knee height. The metal strip which you can see at the end of the join is the rusting metal as it's completely untreated. After having the windscreen resealed and the bulkhead resealed, the leak was identified as being through the rubber grommet that would be the windscreen wiper hole on a left hand drive vehicle. Amazing how much water it was letting in and now completely dry.
Post #505242 16th Feb 2016 6:07pm
JAY BOY
Wales
Mine was the same
They tried 3 times before they eventually sorted it. Thumbs Up
Post #505278 16th Feb 2016 7:48pm
