Home > In Car Electronics > The Puma dip/dim relay myth??????? |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17336 |
Yes it does, in the relay/fuse housing under the column. The easiest way to disable the dimdip is to unplug the connector for the series resistor, located under the offside wing top near the aerial. All you need do is unplug the connector.
8th Feb 2016 7:36pm |
Shiltmeister Member Since: 06 Dec 2014 Location: Mallorca Posts: 32 |
Thanks for the reply. On my LHD Puma this relay doesn't exist under the steering column. The big pink one is the wiper relay.I've hunted all possible alternatives.
Click image to enlarge Is the resistor easy to locate? I hunted all around both wings and around where the arial is. This is starting to get annoying 2009 Puma 110 SW |
8th Feb 2016 8:23pm |
Aha, left hooker, missed that! Pretty sure you won't have dim dip, since it was conceived by idiot British bureaucrats and inflicted only on us.
You presumably know if you had it before you changed the loom and lights. |
8th Feb 2016 9:29pm |
Alien Member Since: 18 Jan 2015 Location: Bacchus Marsh Posts: 230 |
If it's only happened since fitting the harness that's where I'd be looking. Check for an earth wire not being connect that is for the full beam relay. Also check if there is a separate power supply of the same relay, maybe it's not connected or has a blown/missing fuse. A later thought... Is the blue light on the instrument panel lighting up? This should be working if the headlamp switch is good. Cheers, Kyle. |
9th Feb 2016 9:34am |
theorangebandit Member Since: 03 Jun 2013 Location: Stowmarket Posts: 862 |
This may seem like a stupid question but ... Have you checked the high beam fuses ? These are easily blown when fitting things to the headlights if the ignition is left on. They are each fused individually left and right
9th Feb 2016 11:57am |
Yeah the full beam blue light glows on the dash and the indicator stalk switch gear is new. Hence why I'm fitting the new loom as I kept melting them. I will check the relays again in the loom to be sure. Thanks 2009 Puma 110 SW |
9th Feb 2016 4:33pm |
Thanks but yes it was first think I checked. I will not let this defeat me! 2009 Puma 110 SW |
9th Feb 2016 4:35pm |
FIXED!!!
Thank the lord. Rechecked all the connections in the relay holders and after a bit of tugging of everything the +ve crossover between the two relays slid out with a broken crimp on the end. Thanks for your inputs. 2009 Puma 110 SW |
9th Feb 2016 5:56pm |
Good to see it's sorted Cheers,
Kyle. |
10th Feb 2016 9:20am |
